Installing fire engine horns help
Old Apr 17, 2008 | 02:23 PM
JonnyCub's Avatar
Default Installing fire engine horns help
I have on board air and want to install fire engine horns, because my stock horn sucks, and is already gone. just stopped working oneday. i have looked but dont know where to install. please help.
Old Apr 17, 2008 | 02:37 PM
muddpuppy01's Avatar
mount it under the driver side
Old Apr 17, 2008 | 02:44 PM
JonnyCub's Avatar
where at on the driver side. there are not many places.
Old Apr 17, 2008 | 03:08 PM
USAF_GroundRat's Avatar
Here is my thread on it: https://www.jk-forum.com/forums/jk-write-ups-39/fire-engine-horn-board-air-27649/
Old Apr 17, 2008 | 03:59 PM
yetibear's Avatar
then you should return it and buy a set of normal horns. Your dingus does nor grow in proportion to the decibel output of stupidly loud horns, unless you have some really good reason for needing such a horn, then your dingus may grow quite a bit.
Old Apr 17, 2008 | 05:44 PM
mkjeep's Avatar
This is where I mounted mine
Old Apr 17, 2008 | 08:08 PM
JonnyCub's Avatar
Attachment 8081
Attachment 8082
hows yours sound? i want at least two.
Old Apr 17, 2008 | 08:19 PM
mkjeep's Avatar
You don't need 2, trust me. I run my tank up to 140psi and can blow the fur off a squirrel in a tree. Dogs by my house run and hide when they see my JK pull up. Although a friend who helped with the set-up is wanting me to put a horn in the rear and both sides too.
Old Apr 17, 2008 | 08:25 PM
mkjeep's Avatar
You could probably mount another one on the passenger side like the one one the drivers side, if you have the horns check the clearence you would have on the pass. side. I made the bracket out of thick spare aluminum, took all of about 10 minutes.Uh maybe 15, beer break you know
Old Apr 18, 2008 | 02:17 AM
JeepPilot88's Avatar
Hmmm. Why?
