Installing OIL Pressure & Temperature Gauges
Old May 20, 2008 | 02:34 AM
JK07's Avatar
Default Installing OIL Pressure & Temperature Gauges
Are there any problems in terms of oil leaks or oil pressure back to engine valves if i use the oil filter adapter sandwich for oil temp and oil pressure. this adapter will sit in between the block and oil filter. you can install two gauges on it pre drilled.
Old May 20, 2008 | 10:20 AM
mikejwil's Avatar
don't know the answer to your question...but have one of my own
what did you get and where did you buy it? I'm interested in adding gauges too...
Thanks!
Old May 20, 2008 | 05:06 PM
JK07's Avatar
I found few on ebay. If you search for Oil Filter Sandwich Adapter you will get heaps of results
Thanks!
Old Nov 29, 2008 | 12:04 PM
Thanks, big help
Old Nov 29, 2008 | 02:42 PM
sandman's Avatar
I have it installed for about 3K and not a leak just make sure that you tighten everything up really well. I am really happy that I can see the pressure, next it is voltage.
Old Nov 29, 2008 | 06:55 PM
ricrac12525's Avatar
Default Adapter
Thanks!
Online @ Prosport Performance, Part# 3/4UNF-16......$38.99+ Shipping
