Installing TeraFlex 2.5" Budget Boost
Old May 29, 2010 | 02:43 PM
7Creeks's Avatar
Default Installing TeraFlex 2.5" Budget Boost
Can I run stock rims without space with the Teraflex 2.5" BB? Also, is everything I need included with the kit? Thanks ahead of time...
Old May 29, 2010 | 02:45 PM
Sharkey's Avatar
Stock wheels with what size tires?
Old May 29, 2010 | 02:50 PM
I noticed the biggest thing with my stock rubicon wheels/tires was just the mounting of the rear sway bar links..if you dont put them on right the bolts are very close to hitting, but if you place all the linkage and bolts towards the diff side of the mounting tabs they have plenty of clearance.
Mike
Old May 29, 2010 | 02:52 PM
Bowman's Avatar
There's no reason not to be able to use your stock rims. The kit should have everything you need. What are your plans with your jeep? Do you do a lot of off roading?
Old May 29, 2010 | 06:42 PM
7Creeks's Avatar
Nothing to extreme, just some mud on weekends
Old May 29, 2010 | 06:43 PM
7Creeks's Avatar
Goodyear MT/R 255/75R/17
Old May 29, 2010 | 06:59 PM
Serg5000's Avatar
Just fallow the instruction and you should be fine as far as installation. Stock wheels will work. Budget lift's are just that. No other mods required. If I am wrong I'm sure someone can chime in and correct me.
Old May 29, 2010 | 07:57 PM
mattyhfd's Avatar
Mike
would this cause a lot of rattleing and stuff. installed mine today and just b4 i called it a night i noticed my right rear wasnt facing in, and was super close to hitting the inner wheel and wheel weights
Old May 30, 2010 | 04:14 PM
7Creeks's Avatar
Thanks all for the information.... i can't wait to get it put on.
