Installing winch tomorrow...any wiring tips?
The controller on my HF winch stuck several times. I also had a solenoid stick in the on position. To alleviate the stuck controller, I unplugged the controller. To alleviate the stuck solenoid I forced the clutch lever into freewheel and my wife disconnected the battery. If I the winch had been under load I would have needed a disconnect in a hurry.
Just because someone has never seen a failure does not mean it cannot happen. Having a redundant disconnect hurts nothing. If another part fails it can be switched to shut the system down. If the disconnect fails it can be bypassed in the field with simple hand tools. Whether or not you can reach it in an emergency is irrelevant because if you can't reach the disconnect, you also cannot reach the battery terminals.
Having been present for two electrical fires on modified vehicles (not winches, or Jeeps), I can say that a disconnect is an intelligent idea on a modified vehicle. Drag cars have them as part of NHRA rules. Most racing stock cars, even at an amature level, require them.
Seal ... since you don't want to get under the hood or touch a disconnect, what do you recommend in the event of an electrical failure? A Call to 911 I suppose? And for the record an 8mm wench does not remove the battery cables on a JK, you must be thinking of a GM product. Possibly a Hummer.
I have been using the warn quick disconnects on mine.Just squeeze & pull apart.If you do run these,it`s a lot easier to install the disconnects BEFORE you install the winch.And like others have stated,just watch the sharp edges going under the grill/radiator.Good luck!
install solenoid on positive to isolate winch
to protect+isolate chassis electrical use a heavy duty continuous duty solenoid(i use a part # for switched power in Frieghtliner trucks)and have a switch in cab that enables/disables power to winch.winch isolated unless in use.used dual post style gel cell battery,oem connections to top posts,winch neg directly to side post winch batt+ to side post with inline solenoid mounted beside battery hold down.very clean easy install
8MM disconnects the positive connector on the positive terminal, not the the terminal to the battery post. Come to think of it, it might be 10MM...
Just because someone has never seen a failure does not mean it cannot happen. Having a redundant disconnect hurts nothing. If another part fails it can be switched to shut the system down. If the disconnect fails it can be bypassed in the field with simple hand tools. Whether or not you can reach it in an emergency is irrelevant because if you can't reach the disconnect, you also cannot reach the battery terminals..
AGAIN EXACTLY!
You're right it's a 10mm, and I'm talking about the positive connection on the terminal, not the terminal to battery post connection. If you actually connected anything to your JK battery, you should know that...for the record.
This is actually a good idea...
Somebody Needs A Nap!!!!!!
Don't a lot of people open thier hood when they winch? It would be a terrible thing to have to reach inside the hood compartment and turn a switch to stop a full system melt down.
Take a chill Seal20 ....
just because it is'nt your idea desn't make it wrong. There are lots of things that could cause the hot lead to short out no matter what winch you have.
If this idea doesnt apeal to you DONT USE IT!!!!!!
