Jack Stand Placement
Old Jun 8, 2012 | 11:51 AM
Ol' Bob's Avatar
Default Jack Stand Placement
Well it looks like I'll be doing my lift install next weekend. What's the best jack stand placement for front and rear? Remember pics help an old geezer like me.
By the way I ended up with the rough country 2.5 coil with shocks and steering stabilizer.
Wish me luck y'all.
Old Jun 8, 2012 | 12:11 PM
Noxian's Avatar
in the front behind the control arm mounts on the frame, and in the back in front of the control arm mounts on the frame.
Old Jun 8, 2012 | 12:55 PM
finfreeze's Avatar
X2 on just behind the lower control arm mounts. Works like charm!
Old Jun 8, 2012 | 02:43 PM
Ol' Bob's Avatar
Thanks just crawled under the jeep. Looks good. Any pics?
Old Jun 8, 2012 | 03:13 PM
JKUCRUSHMIKE's Avatar
Where are you guys using the floor jack to lift the jeep up for the jack stand placement? Can the jeep be jacked in the center of the frame on the side?
Old Jun 8, 2012 | 05:01 PM
C dog's Avatar
I just place the jack under the axle(center or each side), lift it up and place the jack stands right behind the control arm mounts on the frame. Don't forget to put wood front and back of the tires to keep from rolling.
Old Jun 8, 2012 | 05:23 PM
Ol' Bob's Avatar
Thanks c dog. Wheel chocks will be gotten before I start.
I also saw online that folks are removing the auto trans skid plate which is right behind the lower arms on the front. It's in the way of the jack stand placement if you don't remove them.
I also found all of my torque specs. I'm chomping at the bit, ready. Now I just need my kit to get here.
Old Jun 8, 2012 | 05:33 PM
finfreeze's Avatar
I just jacked up my jeep enough to remove the tire, removed the tire, set the jack stand and let her down.
Old Jun 8, 2012 | 05:38 PM
Ol' Bob's Avatar
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=327159"/>
Very cool. I'm ready to get to it. Hey if any of y'all are near Tallahassee come hang out on Sat the 16. I'm buying.
Old Jun 8, 2012 | 08:07 PM
Dexter Morgan's Avatar
Do you have both front tires off with jackstands on both sides of frame?
