jack stands.
Old May 20, 2009 | 07:00 PM
socal4dr's Avatar
Default jack stands.
what kind should i get??
im mainly thinking about these to chang emy suspension from stock to no more than 3 inches.
what weight and height stands should i get ??>
anyone sellin thiers?
Old May 20, 2009 | 07:34 PM
nthinuf's Avatar
I got mine at a local autozone for $30. 3 ton, 24" height. These are the heaviest duty I found locally. They are beefy enough and worked fine for my lift.
If I had found any heavier stands when I was looking, I would have gone up though.
Old May 20, 2009 | 07:36 PM
paramaniac's Avatar
i got 30" 6 ton after my 3ton (very old and cheap) blew out as i was lowering the rig onto them.
paid $49.95 at pep boys
Old May 20, 2009 | 08:22 PM
RedneckJeep's Avatar
Whatever you do, don't cheap out on them. A cheap jack is one thing, since it is only made to raise a load and not support it. Trying to cheap out on jack stands might be the last thing you ever do.
Old May 20, 2009 | 08:26 PM
paramaniac's Avatar
im glad that i hadnt taken my tires off the JK yet, the explosive sound the stands made as they collapsed just about made me shit my pants.
i do, as a regular thing, put my tire under the frame rail to provide a little extra protection.
my new stands are heavy duty, made for SUVs.
on a sadder, side note.... the day my sister got married ( i was a volunteer fire captain at the time) i got a phone call that one of my fire fighters on my crew was killed when a car he was working on collapsed the jack. he was NOT using jack stands. he was 19. i still think about that when i get under my rig, jack stands not withstanding
Old May 20, 2009 | 09:33 PM
SHIT GREEN MACHINE's Avatar
Like one of the guys said get the best ones you can find it is your life depending on them. Look for the ones with a wide base for better stability. My dads side of the family is all mechanics and we always used iron I beams with extra support welded in. Just a thought if you know a welder
Old May 21, 2009 | 12:12 AM
Foo's Avatar
Foo
I have some 6 ton I think.. heavy duty I bought from sears 15 years ago. The are really heavy duty. if you won't trust them with your life, then don't get them.
Old May 21, 2009 | 07:36 AM
officer_vince's Avatar
I rock 6ton jackstands. I don't take chances with that kind of stuff. I had 3ton ones but at full extension they didn't even get the JK's tires off the ground!
Old May 21, 2009 | 11:17 AM
JackMac4's Avatar
I use 6 ton on my axles, 12 ton on the frame. Mostly for height considerations.
Old May 22, 2009 | 03:28 AM
Muffins's Avatar
I picked up 2 sets of the craftsmen professional ones (yellow and black), they extend pretty high and support well, no complaints
