Jeep Build on 40's Need Advice
No not really. Its your jeep and your money though. Did you feel you had shortcomings from the rubicon on 35's?
From reading your past posts it appears you have very little off road experience as well? Just trying to put the picture together of what you are wanting to do. Will this jeep be a daily driver as well or a weekend toy?
Other then that tires cost more and weigh more.
Long Island, NY. I'll take a wild guess that it's all for show. Then again, they do get a little snow up there. I guess 40's on one-tons then would definitely be needed lol
While I hate California/New York, they aren't all a bunch of poser yuppies.
There is a Seven Slot Syndicate Long Island group that travels to Rausch Creek (drives, not trailered) with 37" and 40" tire JKs, some are long arm/coil overs. They come to wheel... I've played with them a bit and began to follow a husband/wife couple from the group on FB that drove their 2 JKs to Utah last summer to wheel.
Yeah, for some reason when I see the words Long Island / Staten Island, I automatically think GTL - gym, tan, & laundry lol. Probably why I avoid tv "programming" when possible.
No offense to those who live out there and aren't all show and no go lol
Well the axles, wheels/tires, and atlas are going to run $20k steering assist $1500 1350 axles set $1500. A long arm lift in the 4"-6" range, shocks, light bars, air compressor, cage, winch, skids, armor, recovery gear, spare parts (you are still going to break stuff with 40's) and all the other crap that you want to put on the jeep. You can go cheap with this stuff or get quality but I can easily see $10k here. All this is if you are doing all the work yourself. Add another $5-10k if you are paying someone to do the work. Of course you can buy used parts and search around for stuff to save some coin but I was basing the numbers on buying new.
It will be a bad ass head turning jeep. Pick a bright color too if you really want people to stare.
After all this is done and you take it off road you find the trails are too easy to do and will look for harder more dangerous stuff to do that will have a high risk or roll over and body damage. You will also have a heavily molested jeep that will be hard to sell and where you will loose a ton of money on it if you decide to or are forced to sell it. If is a daily driver it will be chore to drive around town in, tight parking lots will suck as the extra width gains great stability in the ride but increased the turning radius. Highway performance will be less then stellar and you will be wondering how much it will cost to put an LS in it ($15-40k)
My general advise after going thru this process is to buy or build a bungie if your off roading can not be done on a JK with 35's, lockers, and proper gearing. Which is also a bad ass jeep with good driving manners and resale value.
I'm on 40's with Dynatrac ProRock 60's, ARB lockers, big brakes, Evo Double Throwdown long arm with King coilovers front and rear. It's setup to crawl but I drive it all over the place. It's also the same setup that they've run KOH and Baja with, and the bypasses are built for speed on a bumpy road. Drove to Moab last year for EJS, wheeled, drove home. Been to San Carlos, Mexico twice. She'll run 90 MPH on the road with no shakes or wobbles, and that's with zero weight in the tires. Proper setup is key.
As was pointed out, a Jeep on 40's gets lots of attention and the obstacles others are struggling on often appear easy and the lines tend to not be as crucial.
All it takes is time and money. Mine started off as a Rubicon, but there is very little of that in regards to running gear left. The biggest benefit is the 4:1 transfer case versus the alternatives in the non-Rubicon models. If you're going to go to the extremes needed for 40's you are better off saving the Rubicon money for upgrades and tackling the transfer case then.
Hopefully that helps a bit.
