Jeep drift issue
Old Dec 31, 2015 | 08:30 AM
Wrangeler X's Avatar
I have a puzzle for you. My setup: 2008 2 door
3.5 RK springs + 3/4 spacers in rear
Fox shocks Adjustable RK control arms
Stock RK front upper ca
Evo rock stars Synergy trackbar, draglink, sector shaft brace, trackbar brace, tie rod
Drag link is flipped
Raised front and rear trackbar
RK rear trackbar
Front and rear Antirocks
Front Rubi axle is sleeves and gusseted
Synergy ball joints
Rear Rubi axle is trussed
5:13 gears
In short, on the gas jeep veers left, off the gas jeep veers right. Can't find play in any joints. Rear pass axle flange is a little bent. It veers enough to to change lanes in about maybe 5 seconds. Steering wheel Doesn't pull and is held straight when it happens.
I've had a couple people say they think the rear end is walking out.
Castor is ~4.5-5
toe is good
Camber is a little off on the pass side but not by much
Tire pressures are even
I'm friggin stumped! Northridge 4x4
Old Dec 31, 2015 | 09:27 AM
JayswranglerX's Avatar
RK rear trackbar
Synergy ball joints
5:13 gears
Castor is ~4.5-5
toe is good
Caster is plenty. Have you centered your axles with adjustable track bars?
Sent from my SM-N920T using JK-Forum
Old Dec 31, 2015 | 10:50 AM
Yes. Axles are centered.
Based on what I know I would guess rear control arm joints or a differential issue. But can't find issue in either.
Northridge 4x4
Old Dec 31, 2015 | 11:20 AM
amok's Avatar
Active Streak: 90 Days
Active Streak: 120 Days
I know you said you checked, but in my experience this was caused by worn rear control arm bushings.
Old Dec 31, 2015 | 11:54 AM
shabbernigdo's Avatar
2nd the control arm bushings. allowing the axle to shift while under load then back when off load.
Old Jan 1, 2016 | 08:01 AM
I agree with control arms... So what is the best way to inspect Krawler joints? When I take them off should I be able to rotate them at all? Here is the bushing end of one of the fronts...
That gap u see is very shallow. NOT all the way through.
Northridge 4x4
Old Jan 1, 2016 | 09:27 AM
DKJEEP's Avatar
Its cracked and its obviously worn. I would replace that bushing even if it wasn't the problem. It cant hurt, that's for sure.
And bushing like that should not be able to rotate.
Old Jan 1, 2016 | 10:38 AM
Invest2m4's Avatar
What are the angles like on your drag link and track bar? Sounds like they are fighting each other and that would be causing your issue. When you accelerate, the front end lifts, axle shifts, etc. When you let off the gas, the suspension compresses. It can be quite a bit of suspension travel and if the angle aren't playing well with each other, you will have the drift issue.
Given that it only happens when accelerating or stopping, I doubt it is worn parts.
Old Jan 1, 2016 | 12:34 PM
Front trackbar and draglink are parallel.
Both track bars are raised with artec raised brackets. Drag link is flipped.
Northridge 4x4
Old Jan 1, 2016 | 12:35 PM
Originally Posted by DKJEEP
Its cracked and its obviously worn. I would replace that bushing even if it wasn't the problem. It cant hurt, that's for sure. And bushing like that should not be able to rotate.
The bushing doesn't rotate.
Northridge 4x4
