Jeep jk 2007 starter
Old Apr 30, 2023 | 10:02 AM
jeep jk r's Avatar
Default Jeep jk 2007 starter
Hi jeep won’t start but after 30 seconds all is fine
when i press the turn on key the starter make a noise i keep the key turned but the noise stops and the car doesn’t start
after 3-4-5 try the car start normally
the starter work and batteries is good
Old May 1, 2023 | 09:13 AM
Dinky Dau's Avatar
Veteran: Coast Guard
Turn on the ignition switch so that you can put it into neutral, push the jeep just a little. While its moving very slow move shifter to park, then try to start.. this will let you know if the flywheel may have a bad tooth.
