JEEP JK 3.8 Engine swap using Caravan motor. DIY with Pics
Old 08-13-2017, 03:25 PM
  #21
jtphoto JK's Avatar
I was asking because the fill spot for the oil looks like it would be right up on the brake booster and going off of memory, the wrangler 3.8 fills from the passenger side. Your pictures confirm that.
Nope all looks same to me. But then to make it all match proper for sensors etc all the external parts like intake and valve covers, pulleys, exhaust manifolds and oil pan and oil dipstick would be used off the JK engine anyway.
Old 08-13-2017, 03:42 PM
  #22
Ametzker's Avatar
Ok that makes sense. I may just use the Jeep valve cover but it will bolt right on. No left to right swap. In reality for my swap it may be better to keep the oil fill on the passenger side because with mine being a RHD Jeep the brake cylinder is on the passenger side and well out of the way of the oil fill either way. I will probably just use the passenger side jeep valve cover.
Old 08-13-2017, 03:44 PM
  #23
Ametzker's Avatar
Exactly everything outside the longblock will be switched over from the Jeep motor.
Old 08-13-2017, 09:51 PM
  #24
Earth Siege's Avatar
I noticed that in 2009 midyear caravan they put out a 4.0L
Is it the same block design-meaning, can it be interchanged with the 3.8L or is it a completely different engine?
There was a 50hp increase between the two but i have no idea if they are similar engines or not.
Old 08-14-2017, 12:04 AM
  #25
Ametzker's Avatar
Complete different engine.
Old 08-14-2017, 04:36 PM
  #26
Ametzker's Avatar
ID:	674110My daughter loves the Jeep also.
Old 08-18-2017, 04:54 PM
  #27
Ametzker's Avatar
Just ordered my rims tonight. Wife doesn't know......yet. The price was unbeatable. 20x9 set of 4 delivered for $449.
Old 08-22-2017, 03:38 PM
  #28
Ametzker's Avatar
Been trying to get work done but all our weekends have been taken up. Today went to Danville, Ill to pick up my engine from the terminal. Started pulling the motor until I sliced a giant chunk of meat out of my finger. Tomorrow I will have the engine out and start swaping parts over.
Name:	Jeep engine pull 003.JPG
ID:	674271 Click image for larger version
Name:	Jeep engine pull 004.jpg
ID:	674272Click image for larger version
Name:	Jeep engine pull 005.jpg
ID:	674273Click image for larger version
Name:	Jeep engine pull 012.jpg
Name:	Jeep engine pull 016.JPG
ID:	674275Click image for larger version
Name:	Jeep engine pull 013.JPG
Here is the vid. https://www.youtube.com/watch?v=1aonQLUcXEU
Old 08-23-2017, 03:09 AM
  #29
Rednroll's Avatar
I'm really wondering while you're pulling that all out, if it might be worth looking for a newer/less mileage trans as well? As you say in your video, the old engine had almost 300K miles on it. Kind of thinking a trans with 300K miles on it, can't be too far behind of needing replacement.
Old 08-23-2017, 04:27 AM
  #30
Ametzker's Avatar
It's a good point. I did get a chance to drive it and the trans feels pretty good. I plan on doing a diesel swap in the next 2 years. No adapter companies make an adapter plate for the 42rle trans so I didn't want to buy a new trans if I'm only going to have it like this for a year or so. It will either have a OM617 or a 3.9 cummins and there are several engine to trans and trans to transfer case adapters for those engines.
Quick Reply: JEEP JK 3.8 Engine swap using Caravan motor. DIY with Pics
