jeep squeaking
as mentioned, try rocking your jeep side to side as opposed to bouning it up and down. if that give you a squeak, have someone continue to rock it back and forth as you go around putting your hand on things like your shocks and sway bar links. based on your profile and what you have on your jeep, i'm going to bet that the squeak is coming from one of them and if it is, the component will vibrate a bit when it squeaks. if i could guess, one of your shock or sway bar link bolts is just a tad loose and this is causing the bushing to rotate thus causing a squeak.
Ok thanks. I thought it could be a shock or something. I'll try rocking it as well. Wish my driveway was not a potholed gravel hill so I could try to do this on a flat surface. If its a shock should I jack the jeep up to tighten it or will I be kosher with it unjacked?
okay, that still helps and eliminate that. next, you'll want to check things like rocker guard and/or skid plate bolts. sometimes, these can come loose just driving around on rough roads and and they rattle around, they can cause a squeak.
Originally Posted by SWAT524
Take you jeep into the shop the squeek is th
