Jeep step?
Old May 15, 2013 | 07:53 PM
ColoradoJeepWife's Avatar
Default Jeep step?
Our Jeep (3" lift and 33" tires) has just become my daily driver and I'm only 5'3". Needless to say, this is problematic when going to work and wearing a skirt. Can anyone recommend a sturdy step that I can use when commuting but remove when 4-wheeling? I don't mind the height at all when dressed for wheeling. Thanks!
Old May 15, 2013 | 08:00 PM
Jeek.OlllllllO's Avatar
I remember seeing some rock sliders that turn Into steps when you open the door I think reble off road has them not sure
Old May 15, 2013 | 08:05 PM
jeeeep's Avatar
do you already have any type of after market rock rails? several options depending on budget:
M.O.R.E. Hide-A-Step
Olympic 4x4 Products Quick N Easy Step
Carr HOOP II XP3 Black Powder Coat Steps
Saw these at EJS this year - saw these guys run the trails with it on and it still worked:
Rock-Slide Engineering's rock-sliders
Old May 15, 2013 | 08:08 PM
Fugg it's Avatar
here's a couple options I've been thinking about cause my wife has a tough time climbing up too. they're cheap and tuck outta the way
this one is spring loaded so as u step up, it closes and hides away
this one has to be let out and brought in manually
amp research makes the electric ones that are cool but expensive
Old May 16, 2013 | 12:52 AM
carlojp's Avatar
Check out the AMP Research Power Step for JKs. It is a retractable stepping board so ground clearance won't be affected
