JK axle bent at 21K miles - anyone else have this problem?
It was less than 2 months and 2,000 miles on my lift and 35 BFG KM2's and the rear axle is bent. Felt a 'buzzing' thru the gear shifter at freeway speeds was the only indication.
The 'great' guys at my local 4Wheel Drive Parts knew exactly what it was, from my discription, and verified it up on the stands with wheels rotating you could see a wobble - they said they have seen it on non-mod Jeeps as early as 15,000 miles and some with more than 70,000 miles and hard wheeling no sign?
Just wondering how many on here have experienced this???
It was at 21,000 miles and a rear axle, you could see the caliper moving in and out, so not a bent wheel (alloy). 2009 JK 'X' model so dana 35 rear and 30 up front. I wheel it pretty tough, but not extreme - they knew of the problem, so figured someone on here had it happen?
Looks like the railroad might be up to its old tricks again, they would chain them down so tight the chains would bend the axle, just something to ponder. The stealership today don't inspect new vechicle like they use to.
Did you not have any vibration? I would think that if you could "see" a wheel wobble while up on the lift, at Hwy speeds you'd be shaking some fillings loose.
As far as troubleshooting, i would X2 what wayoflife has recommended. get a cheap dial indicator from harbor frieght (or other) and remove rear wheels. (remove both sides) start from the axle flange and work out on both sides. (axle, rotor, wheel).
I'd be suprised if you bent your housing....so an axle replacement is an easy fix and there are plenty of guys on here selling OEM axles for cheap$$$$. pick up spares for the future
Keep us informed
