JK Fuel Pump GPH
Old Feb 19, 2014 | 11:20 AM
Maertz's Avatar
Default JK Fuel Pump GPH
Anyone know what the GPH of the stock fuel pump is? I will be needing an external fuel pump. Ive been looking at jk specific ones and they vary from 43 gph to 125 gph. Even on Autozone im not finding a fuel pump for the jk. I just need to know the ballpark gph so i can make sure the external pump for my fuel cell will provide enough. Fuel pumps are not my expertise at all, but I am learning a bit on these.
Old Feb 19, 2014 | 11:31 AM
ronjenx's Avatar
I would think most any electric fuel pump will be enough flow for the JK.
What's the most you will burn in an hour? 10 mpg is 6 gph at 60 mph.
Pressure is more important. The OEM pump is regulated to 58 psi +/- 2 psi.
What are your plans with the fuel cell?
Old Feb 19, 2014 | 11:33 AM
Maertz's Avatar
Perfect, i figured youd be the one to help me out. I will look into the pressure then. Whats the consequences of running a slightly higher/lower psi? If i cant find exact is there a better side to error on? I appreciate your help.
Old Feb 19, 2014 | 11:40 AM
ronjenx's Avatar
If you go too far plus or minus, the computer may not be able to compensate for the different flow rate through the injectors. And, the spray pattern/atomization may not be satisfactory.
I have no idea what pressure would be too high or too low.
Old Feb 19, 2014 | 11:42 AM
Maertz's Avatar
Ok sounds good ill see what i find. Im sure theres one out there. I believe Carolina truggies used one so i can always ask them if i cant find one
Old Feb 19, 2014 | 05:05 PM
Maertz's Avatar
LS1 Complete Fuel Delivery Kit - Speedway Motors, America's Oldest Speed Shop
this looks perfect.
MSD 2225 In-Line Hi-Pressure Fuel Pump - Speedway Motors, America's Oldest Speed Shop
but when i look up just the pump this is the specs.
From what i can see the kit has a regulator that keeps the psi stable where i would need it correct? But wouldnt the psi very depending on rpms/ the need for gas?
Old Feb 20, 2014 | 02:27 PM
Maertz's Avatar
little bump to make sure i got that right?
Old Feb 20, 2014 | 05:46 PM
ronjenx's Avatar
...Pm sent...
