JK Heim Steering
Old Oct 20, 2015 | 09:41 AM
kjeeper10's Avatar
Vet Army
I will be trying out the new SteerSmarts "no drill" drag link. Also their tie rod.
Look for it at SEMA and to be available soon after.
All you will need is a track bar bracket to run a highsteer kit.
http://steersmarts.com/products/jk-w...mount-draglink
Old Oct 20, 2015 | 11:55 AM
Maertz's Avatar
Does that raise the tie rod also or just
Essentially work like a drag link flip?
Old Oct 20, 2015 | 12:55 PM
kjeeper10's Avatar
Vet Army
Originally Posted by Maertz
Does that raise the tie rod also or just Essentially work like a drag link flip?
I linked only the drag link. There's going to be three options. Top mount, bottom mount, and one if the knuckle has already been drilled.
Another cool feature. The rod ends have a anti-flop feature built it.
Here is the link for both Tie Rod and bottom mount drag link. The site is not completed yet. They will have the other drag link options packaged with the tie rod.
http://steersmarts.com/products/yeti...eering-linkage
This set up is comparable to Currie, albeit cheaper, A better design, and boot seals that won't spit crease after one wheeling trip
Old Oct 20, 2015 | 02:04 PM
kjeeper10's Avatar
Vet Army
Teaser
ID:	627961   Click image for larger version
ID:	627962   Click image for larger version
Old Oct 20, 2015 | 02:35 PM
Maertz's Avatar
So its just a drag link flip it looks. My bad i pictured high steer as raising drag link AND tie rod up out of the way like reids knuckles or similar. Thats what i was implying to do if your constantly bending tie rods.
Old Oct 20, 2015 | 03:03 PM
kjeeper10's Avatar
Vet Army
Gotcha !! Heres the YETI installed. Toe angle is not set but its as easy as turning the center section. Clamps 40 ft lbs.
Edited finished install
ID:	627974   Click image for larger version
ID:	628351   Click image for larger version
ID:	628352   Click image for larger version
