JK Lean
Old Oct 24, 2011 | 07:12 AM
Adam in CO's Avatar
Default JK Lean
I have a 2011 JK Unlimited Rubi with a 4" Pro Comp Stage 2 Long Arm kit and it leans to the right. Thoughts?
Old Oct 24, 2011 | 07:23 AM
jsears's Avatar
Springs are on the wrong side I believe some kits include slightly taller springs for the side that has the gas tank.
Old Oct 24, 2011 | 07:30 AM
SiliconTi's Avatar
Mine does that with a Rough Country lift. Springs are the same left/right. I ended up helping it with JKS spring perches (cut off the old and bolt on this one). It still sags to the right, but only by about 1/2 inch.
Fuel tank does it. Note that out of the factory, the springs left/right are not the same.
Old Oct 24, 2011 | 07:38 AM
Southern Girl's Avatar
Switch em' and you're good!
Old Oct 24, 2011 | 08:03 AM
Full-Traction Suspension's Avatar
Former Member
I'm not sure anyone vendor does this, I could be wrong..
As suggested swap sides and see if that helps
Old Oct 24, 2011 | 08:06 AM
weebus's Avatar
Default lean
mine does this also im glad im not the only one i would like to hear a fix i have a 3" bds lift
Old Oct 24, 2011 | 09:12 AM
Biggy's Avatar
Make your swaybar links longer on the side thats leaning
Old Oct 24, 2011 | 10:16 AM
aermotor's Avatar
Besides swapping the springs don't do anything else suggested...... Find and fix the real problem. How much of a lean are we talking about?
Old Oct 24, 2011 | 10:41 AM
jsears's Avatar
I know you guys don't!
BTW your new sway bar links rock!
Old Oct 24, 2011 | 10:48 AM
Biggy's Avatar
Originally Posted by matzjeep
Now why in the world would you do such a thing?
Lol just something i read on here before. Try searching the subject. I believe wol even gave that advise. I may be wrong though
