JK Lean - what did you do?
Old 12-09-2013, 09:10 PM
rrands1's Avatar
Default JK Lean - what did you do?
I have the infamous JK Lean to the passenger side - so much so that my buddy driving behind me to a trail called to ask if I was hauling fat chicks on the ride...
I am ordering 3/4" spring lifts for the passenger side, but thought (after the fact, of course...) that I would ask to see how others have handled it? My other thought was to pre-load the sway bars, but that will mess with my e-disco on the front, I think...
Thoughts?
-randy
Old 12-09-2013, 10:59 PM
JHP81's Avatar
I thought u can play with the length of the sway bar links to equal out the lean. Try that.
Old 12-09-2013, 11:24 PM
Tooadvanced's Avatar
Most of what I've seen it spacers to level it out
Old 12-10-2013, 05:10 AM
Mack0092's Avatar
I have a little JK lean. I first noticed it when I was trying to reconnect my sway bars. one side of the disco slipped on and the other was about an inch and a half off. I pulled the jeep up on a block of wood to even it out and the other side slipped right on. Yes the Jeep was on flat ground while performing this.
Old 12-10-2013, 07:27 AM
bombout800's Avatar
I have a 1/2" spacer on the front driver side to equal it out. Now it's within an 1/16 th of an inch
Old 12-10-2013, 09:11 AM
TheDirtman's Avatar
coilovers will take care of it.
Old 12-10-2013, 11:36 AM
Even if the rates are all the same? Its a problem of 200lbs of gas on passenger side so if rates the same wouldn't it still lean? I trust you though with all your knowledge just curious
Old 12-10-2013, 11:44 AM
HardRooster's Avatar
Move the gas tank to the back.
Old 12-10-2013, 12:08 PM
jadmt's Avatar
My tank can be almost empty or completely full and it changes nothing on my lean. empty or full the passenger side is 3/4" lower in front and the same in back by same I mean the back has no lean. I thought maybe it was designed that way so when you had only the driver but I measured that way too and no difference.
Old 12-10-2013, 12:56 PM
ronjenx's Avatar
The gas tank causing the lean is a very common misconception.
I weighed my JK with half a tank of gas and found the left and right sides to be equal in weight. (Stock, no extras, no driver)
Quick Reply: JK Lean - what did you do?
