JK Pentastar Swap
Old 11-12-2015, 09:09 AM
  #71
Invest2m4's Avatar
Originally Posted by Yankee
My Rubi suspension and power steering are still working fine after near 60k of abuse. Little sag but probably as much to do with steel bumpers and winch as engine and tranny. Still using the original stock driveshafts. Cannot believe the rear shaft (and the pinion angle did increase with the conversion) is still intact. But YMMV as I am still stock on tires and suspension.
Sure you can install without a kit. However, if I were to again put in a Hemi or LS I would still buy a kit again and be done with the hassle. If my budget was that tight personally I would just not do it at all. The pre-configured lines, harness, computer, etc are just too sweet and greatly decrease the likelihood of codes and problems.
Guess it depends on how much time and stress one wants to spend sorting problems out instead of driving. For some people the Jeep is their DD and work/family does not allow the time.
All that said, I have great respect for the OP's efforts (and steel nerves) to do that 3.6 swap.
Right, I'm saying you buy the computer, wiring harness, motor mounts, radiator and fan from JSS. Reality is that for me, the rest of the kit won't work in my Jeep. I flat bellied it, so I have to build my own transmission mount. Air filter can't go where they put it as I have strut towers than run up to the hood. Battery and fuse box are relocated with my custom mount due to that as well. I mean, just about every mount in my Jeep is custom and made by me. There is no magic to the rest of the kit they sell. I see no reason to pay $3k for stuff that can be made for $100 and improved on. Why not gain 3" of belly clearance just by making a simple design change to the trans mount? At least for me, that ground clearance makes a huge difference wheeling in the rocks.
Old 11-13-2015, 07:27 AM
  #72
Yankee's Avatar
I agree with all your points. For those of us without your fabrication skills and/or time and not having your mods, the kits are still nice to have available if one is willing to lay out the money.
Old 11-20-2015, 05:52 AM
  #73
Saharacon's Avatar
So which is better bet (cost & effort, as well as fuel economy & power): 3.6 with Supercharger, Hemi, or LS swap? Similar power outputs.
I would be interested to know from those who have done it.
As for posting documentation on wiring for my project, I have it mostly finished. I still need to include the details about connectors I needed to add (for brake booster and AC transducer). I can post it incomplete and update, or I can wait until its done. Opinions?
Old 11-20-2015, 06:31 AM
  #74
jedg's Avatar
I still think the Hemi or LS is a better choice in the long run. The tuning for these platforms are much more understood. Bigger market. Less complicated tuning.
Old 11-20-2015, 08:29 AM
  #75
Yankee's Avatar
I don't know which is better. Some of us old-timers are just V-8 guys from way back and disregard what might be practical. We want that rumble and seat of the pants feel a V-6 cannot duplicate. I would think boosting a 3.6 might be easier to DIY and cheaper though.
Regardless, the fact that you tackled and completed the swap on your own with no pre-charted path demands much respect.
Old 11-20-2015, 11:24 AM
  #76
Elusive's Avatar
I've had a supercharged 3.8 and I have a hemi.
the power outputs are NOT similar.
I live in a mountainous area. the 3.8 used to be spinning at redline the whole time on the freeway with any incline. The hemi rarely downshifts. there's no comparison in real world applications.
Old 11-21-2015, 05:19 AM
  #77
scubatech's Avatar
That's my observation as well.
Old 11-21-2015, 06:17 AM
  #78
jedg's Avatar
Yeah... I had a RIPP SC on my 3.8.. now I'm running an L96 6.0L... quite a bit of difference. I haven't ridden in a 3.6L with an SC though.
Old 09-07-2016, 04:55 PM
  #79
Warthulk's Avatar
Default 3.8l Automatic to 3.6l supercharged swap.
I have the opportunity to buy a 2015 3.6l with a Eddlebrock supercharger, and a new Diablosport unlocked PCM, along with other assorted parts removed when he swapped to a 5.7l. I cannot find any good info regarding what would be required to make this swap... or if the bellhousing will even bolt up.Any and all info you can share would be most aprreciated!!! Subscribed to this thread!!!
Old 09-07-2016, 08:03 PM
  #80
VEGASROBBI's Avatar
Were working on a few outside of the box projects for the JK including a diesel and this low cost LFX engine from a Camaro. The LFX is available in 330 to over 400 HP variants. The LFX is available with direct injection and 6/8 speed transmissions, a big advantage over the 5 speed automatic IMO.
With all the LS and Hemi's we do it will be interesting to see if a small displacement engine can haul a JK properly. It's fast in a Camaro, we have a LFX 8 speed Camaro in the shop now and were getting over 30 mpg with it.
https://www.youtube.com/watch?v=iVm3VBI1cvc
Quick Reply: JK Pentastar Swap
