JK for Snow
Old Feb 19, 2008 | 02:10 PM
88Crusher's Avatar
Default JK for Snow
What makes a good setup for wintery driving and wheeling?
I only live in PA right now but I have plans to move north pretty soon and playing in the snow
Old Feb 20, 2008 | 06:03 AM
[N]UGE's Avatar
I've been in 50cm er... 20 in of snow here in toronto and up north at my cottage.
I have 35"x12.5" Dick Cepek mud countrys. They work great in deap snow and on the trail.
Old Feb 20, 2008 | 06:09 AM
jkkat's Avatar
On-road siped BFG MT KM DT's stock rubi size
Off-road something wider and taller with lift and aired down
Old Feb 20, 2008 | 06:41 AM
RevyJKU08's Avatar
If you can afford it.....look at the mattracks and check out the video clips in the snow.
http://www.mattracks.com/
Old Feb 20, 2008 | 10:05 AM
wgr's Avatar
wgr
For a deep snow i use narrow tires, to dig thru and get a grip, also less resistance during forward motion in a snow over 1 foot deep. Snow means less friction between tire and a surface. Also it makes a difference if it is wet snow, old or new snow, or a really cold out there (-15 celsius and below) as these snow/water particles and molecyles behave differently in each of these mentioned cases but not only.
Old Feb 20, 2008 | 10:11 AM
LarryJ's Avatar
Default You don't need much
I have lived in northern Wisconsin all my life. With lake effect snow and getting at times 300 inches of snow, yes I said 300 inches in a year, I have some experience. I'm 44 years old and have a fleet of 51 business cars and trucks; I'm a volunteer fire fighter, worked for 15 years driving ambulance and friends on the sheriff department. I know about driving in the snow and tires.
You can add this, that, and the other thing but, when it comes down to brass tacks, it's all about the tires and the weight.
Most of your snow will be on a road. If it is hard packed, not ice, the factory wranglers are great. Options such as limited slip, positive traction, or whatever the terms are these days will help allot. I have had light snow coming over the hood into the windshield and still didn't get stuck. I have never been in the position to be in that much snow that I didn't have traction either from the snow base or the ground itself. As far as having bigger tires, go taller, not wider!!! Tires that have more rubber will bite less unless, you’re in three feet of hardened snow. I have seen this once in my life were the larger mudder did better than a "Pizza Cutter" tire.
Weight is a topic you have little choice over. But if you want traction in the snow, adding weight is critical. You would be amazed what a couple of filed sand bags will do.
Old Feb 20, 2008 | 10:39 AM
88Crusher's Avatar
right now Im looking at either pro comp mud terrain or BFGoodrich Mud terrain 33x12.50x15
how is that size, should i go with a 10.5 instead?
Old Feb 20, 2008 | 10:45 AM
LarryJ's Avatar
Default Make it easy
If your looking for the ideal setup, have two sets of tires and rims. Larger tires chrome wheels for spring, summer, amd fall. Then get a set for the snow, so the salt can eat away a set of less expensive wheels.
Old Feb 20, 2008 | 10:50 AM
88Crusher's Avatar
well i am going to get black steal wheels so im not looking for something pretty, I dont mind the salt and crud
Old Feb 20, 2008 | 11:02 AM
DavidEllzey's Avatar
So how much do these toys cost? Also, with an assembled weight of 1400lbs (350 ea) I can't imagine its an easy switch to go from tires to tracks then back again.
Dave
