JK Wheels 101
Old Jan 24, 2008 | 10:56 AM
  #21
WaIIbanger's Avatar
this is embarrassing, but i have never switched wheels except for my YJ, and those were mopars that bolted right on.
why does the whole backspacing/offset thing seem backwards to me? why doesn't adding spacers behind the wheel push the tires out instead of in?
i know i'm an idiot. i'm still figuring out left to loosen.
Old Jan 24, 2008 | 11:08 AM
  #22
wayoflife's Avatar
JK-Forum Founder
Originally Posted by Moetop
Is this Info in any of the FAQ's.. couldent find it in the wheel and tire, but that was modified section.. Might be a good idea to add it to the FAQ.
Actually, it is:
https://www.jk-forum.com/forums/show...74&postcount=3
Old Jan 24, 2008 | 11:11 AM
  #23
wayoflife's Avatar
JK-Forum Founder
If you look at the original diagram that I posted...
...you can see that reducing the amount of back spacing will bring the mounting pad closer to the axle. This in turn pushes the entire wheel outward. Can you see what I am talking about? Adding wheel spacers effectively do the same thing - reduce the amount of back spacing.
Old Jan 24, 2008 | 11:22 AM
  #24
WaIIbanger's Avatar
thanks for the quick reply.
well, let's forget the spacers for a minute and look at your offset. why is it when i look at your diagram, it looks to me as if the tires would be pushed out, not in?
to me, it looks as if the wheel were offset in the opposite direction, then the tire would be pulled in.
i like to think of myself as above average intelligence, but i'm just not getting this.
Old Jan 24, 2008 | 11:29 AM
  #25
wayoflife's Avatar
JK-Forum Founder
Looking at the diagram, the left side is the inside of your wheel - the side that attaches to your axle. If you reduce the amount of back spacing, the distance between the center line of your wheel and mounting pad will increase. This will effectively move the entire wheel towards the right - outward.
Old Jan 24, 2008 | 11:31 AM
  #26
Moetop's Avatar
Ok I must be really stupid, because I do not see anywhere in that document where it describes the various stock wheel sizes
This part of this post.
X Standard
Painted Steel - Size 16 x 7.0
X Optional
Painted Cast-Aluminum - Size 16 x 7.0
Sahara Standard
Painted Cast-Aluminum - Size 17 x 7.5
Sahara Optional
Painted Cast-Aluminum - Size 18 x 7.5
Rubicon Standard
Machined Cast-Aluminum - Size 17 x 7.5
I dont see it in their
Old Jan 24, 2008 | 11:33 AM
  #27
wayoflife's Avatar
JK-Forum Founder
My apologies, you are right and will try to add them in.
Old Jan 24, 2008 | 11:45 AM
  #28
WaIIbanger's Avatar
and so how does this bring the tire in?
what i am seeing would be the same as a puck for a body lift. you put the puck on and the body is father from the frame.....not closer.
or like putting washers on a tricycle before putting a rear wheel on.
i appreciate you trying to explain this to me, but i don't want to waste your time. one of my best friends works at a local auto parts store and i will have him give me a lesson on offset/backspacing.
sorry i don't get it.
Old Jan 24, 2008 | 11:54 AM
  #29
wayoflife's Avatar
JK-Forum Founder
It wouldn't. I would push the tire out. Less back spacing will give you more clearance between the inside sidewalls of your tires and the frame of your Jeep.
This is correct and I'm starting to think that you have gotten it all along and perhaps there was just a misunderstanding.
i appreciate you trying to explain this to me, but i don't want to waste your time. one of my best friends work at a local auto parts store and i will have him give me a lesson on offset/backspacing.
LOL!! Actually, I think you do get it.
Old Jan 24, 2008 | 11:55 AM
  #30
atomicmecha's Avatar
wish i was at home, i could make a little gif animation to explain it. But yeah, wheel spacers are like pucks for a body lift. they push the wheel and tire out, away from the vehicle.
so take the stock backspacing of 6.25" and the wheel is 7.5" wide. so that means that the outside edge of the wheel is sitting 1.25" away from where it bolts to the axle (give or take a few mm ). now, you add a 1.5" wheel spacer, it will push that wheel out, away from the vehicle because its putting a bigger gap between where the wheel bolts to the rotor. so now the backspacing is 4.75 (6.25-1.5=4.75) and now that same 7.5" wide wheel is sitting 2.75" out, or 1.5" futher then before.
the wheel spacers push the wheels away from each other on the same axle is another way to put it.
dunno if any of this helped or not...
