JK wheels on TJ
Old Apr 9, 2007 | 03:52 PM
jared1843's Avatar
Default JK wheels on TJ
Will my stock JK 17's with 32 inch rubber fit on a 2001 TJ with no lift? If it won't fit, how much lift would it need?
Thanks in advance!
J
Old Apr 9, 2007 | 04:00 PM
2K1TJ's Avatar
It's a no on the wheels. They're the wrong lug pattern.
Not sure about the tires. It'll be close. I've heard of people running 31's w/ no lift.
Old Apr 9, 2007 | 04:28 PM
Gasser's Avatar
You could buy some spacer/adapters so they will fit your TJ and also space the wheels out. If you rub after that then just add a little boost to your lift if needed. If you don't do major rock crawling then you will probably make it. Just make sure you get the right adaptor to change your bolt pattern from The TJs to the JKs pattern.
Jeff
Old Apr 9, 2007 | 07:34 PM
jared1843's Avatar
Anyone know where I can get the right spacer/adapter to fit JK wheels on a TJ???
Old Apr 9, 2007 | 07:37 PM
jared1843's Avatar
Anybody??
