JK X D44 and Rubi 44 Locker
dpoelstra did it, ask him it wasn't as easy as a simple swap. Axle spline counts are different, as are the axle lengths and bearings I believe are totally different
here
https://www.jk-forum.com/forums/show...ra+rubi+locker
here
I picked up a rear rubicon elocker cheap and am going to try this install at the same time I change out gearing. As someone mentioned, you need to upgrade the axles to 32 spline. Had I done the ARB I would have upgraded the axles as well so that part was a wash.
The wiring is the scariest part. The rubi has an area ground flat on top of the pumpkin with a huge hole drilled in for the wiring connection. I am still debating whether to try to duplicate that mod or just drill a small hole put the wires through using a grommet.
I'll post a write up when I complete it in a couple of weeks.
I also have an '09 4-door with the rear rubi locker and E-disco up front. It's an S package and has the 3.73's
I was looking for green but when I saw the options on this one and was offered right at $3000 off the sticker now I'm sportin' yellar.
Interesting ... I did not know those options were available in 2009 .... They were definitely not on Jeep's Build website for the 2009 model year.
Not a bad build sheet.
Oh, and I looked at the Buy Order again. I was wrong about the $3000 off. They gave me $3,174 off the sticker PLUS the $1000 rebate.
Right time right place I guess, Chrysler filed Chapter 11 a couple weeks before the sale and this dealer was on the chopping block. I requested and got a letter from Chrysler Corporate at the time stating that the warranty would be honored (either by them or Obama ) if they went belly up and the dealer reopened under a new name about two weeks later.
there is a lot of questionable information in this thread.
Rubicon axles are 32 spline in the rear only. The front axles are 30 spline. The rear of the X/Sahara Dana 44 are also 30 spline, leaving some to believe that the front locker should just drop into the rear X/Sahara Dana 44. From my write up you can see it is not that easy.
Wiring up a locker is as easy as a couple of wires and a switch. No re-flash needed.
The "Locker" axle offered in the X is in fact the Rubicon Axle assembly, including the locker. I am not familiar with available gear ratios.
Please be careful answering questions in such a definitive way when you don't know for sure.
If you want to make look and feel like the factory setup, a bit more than "a couple of wires and a switch" is required.
Good advice, but why are you picking on this thread? Have you looked at the thousands of other threads that have questionable, misleading, incomplete, or inaccurate information? For that matter, have you looked at the internet in general? This is just friends helping friends - warts and all.
I know this one just caught me in the wrong mood, and I went through torture to learn what i learned. Drives me nuts to have people answer like they know everything and they are just plain guessing. I would hate to see someone make a big expensive mistake on the word of some yahoos, but then I guess if someone trusts everything they read then they deserve it?
Never mind...just grumpy...
