jks quick disco's front end bump
Old Aug 30, 2009 | 06:24 AM
snosurferjeep's Avatar
Default jks quick disco's front end bump
installed jks quick discos and now when i pull out of my driveway which has a slight drop to it and the front end flexes i get a bump feel and sound like the bimpstops are bottoming out. could i have the sway bars too short and the swaybar is too tight when it flexes?
Old Aug 30, 2009 | 06:39 AM
mkjeep's Avatar
Your swaybar should be level with the links +or- 5degrees and both set to the same length
Old Aug 30, 2009 | 07:27 AM
wayoflife's Avatar
JK-Forum Founder
what he said but i would also double check to make sure that the mounting pins are secured tightly especially on the axle mounts. if they are loose a bit, they can cause clunking.
Old Aug 30, 2009 | 08:47 AM
thanks i will check, also should they slide off the posts easily? mine are very tight to get get off.
td
Old Aug 30, 2009 | 09:31 AM
EHarris's Avatar
JK-Forum Ambassador
td
Mine do not slide off easily. Maybe because I have not been on perfectly level pavement when I go to pull them. I was wondering the same thing.
Old Aug 30, 2009 | 09:36 AM
mkjeep's Avatar
One of mine slides off easily, the other fits really snug. push on the bumper abit and it comes off. The more level ground your on, the easier it is.
