JKS Rear Trackbar install
Old Aug 13, 2018 | 07:58 PM
remo427's Avatar
Default JKS Rear Trackbar install
When installing a new JKS rear trackbar, do I need the JKS rear trackbar bracket also?
Background: Installing Jspec 2.5 lift kit on 2017 Rubicon Recon. Also added the front and rear control arms and the rear trackbar.
Just not sure if I use the included rear trackbar bracket with the rear adjustable trackbar.
Thanks for any help.
Old Aug 13, 2018 | 08:23 PM
nthinuf's Avatar
An adjustable trackbar centers the axle, while leaving the bar at a steeper angle (due to the lift height).
A raised rear bracket will center the axle (though not as well as an adjustable), while also helping with the angle/roll center.
So, no, you do not 'need' the bracket. But, you might find that it handles better with the bracket installed.
Old Aug 13, 2018 | 08:46 PM
remo427's Avatar
Thank you for the answer: "So, no, you do not 'need' the bracket. But, you might find that it handles better with the bracket installed."
I'll be installing the bracket.
Old Aug 14, 2018 | 07:35 AM
jk_southwest's Avatar
The rear track bar mount has been a weak spot for many folks. Installing the bracket will help to reinforce this area.
Old Aug 14, 2018 | 05:38 PM
lowendrider's Avatar
I have the same lift and used the bracket only with the factory rear track bar. Works great.
