Just noticed
Old Mar 7, 2010 | 04:33 PM
geekguy's Avatar
Default Just noticed
I just noticed this on my front drive shaft:
[IMG][/IMG]
I replaced the clip but I am not sure how long this will last with that much seepage. Am I going to need to replace this anytime soon?
Old Mar 7, 2010 | 04:47 PM
wayoflife's Avatar
JK-Forum Founder
[IMG][/IMG]
naw, you'll be fine like that for a while. once the grease dries up, it will squeak and if you keep on hitting your tranny pan, it can cause it to leak. a front u-joint style front drive shaft should be on your to do list but, it's not urgent.
Old Mar 7, 2010 | 04:54 PM
geekguy's Avatar
Thanks for the input!!!
Old Mar 7, 2010 | 05:27 PM
silver rubicon's Avatar
i had the same problem as soon as i put the lift on (and as you know, it threw grease all over the undercarraige). but my fix was to use a zip tie instead of the factory clamp. others on the forum who used the factory clamp say it will just rip off again. the zip tie has a lower profile and so far has not been ripped off -and its been about two years.
Old Mar 7, 2010 | 05:39 PM
geekguy's Avatar
I'll have to do that. I could not find a new clip anywhere.
