K and N cai install
Old Jun 13, 2010 | 02:41 PM
Firefighters_Axe's Avatar
Originally Posted by Crasher
When they offer a sleeve to filter out more dirt and don't recommend it for offroad conditions, doesn't that tell you something?
Thats for liability reasons....
Ive used it before and they work wonders.
Old Jun 17, 2010 | 07:54 AM
dkulakow's Avatar
Thanks for all the input! I just put in my order and I'm going to be going with the company that I ran with in my last jeep, K&N.
Old Jun 17, 2010 | 08:36 AM
m&mjkx's Avatar
Cool
Can't tell much difference because I dropped the K&N on the day I brought it home, nothing to compare it to... does make my son smile with the sound it make when I stand on it... no regrets yet.
Old Jun 17, 2010 | 08:49 AM
Don't worry about the bolts. The reservoir won't move when you pull the bolts and you put them right back in when the shroud goes on (shroud keeps the filter separate from the engine, comes with the kit). The engine bolt removal isn't too difficult but I will say that this was "the hardest part", not that it was all that difficult. The thing about it is that there is a captive washer on the bolt. There is very little clearance no matter how hard you try (or at least in my situation) you can't avoid raking the washer across the inside of the serp. belt. Not really a problem, just make sure you're careful there and don't gouge it. Anyhow, it's a pretty easy install. I would also recommend disconnecting your battery when you do it. It's not necessarily "required" but this will force your computer to adjust for the added airflow much faster. It'll still take some time but not nearly as much as it would if you don't disconnect it.
By the way, if your mpg's seem to go down for some reason (like mine did), that's most likely because you can't keep the pedal off the floor, since it sounds so mean at higher rpm's. Lovin' it.
Old Jun 17, 2010 | 09:06 AM
Default Forgot the Pics
Easiest "Drop In Air Box" I've ever installed....
And one with the Big Blue Optima...just because...
Old Jun 25, 2010 | 10:08 AM
dkulakow's Avatar
So i was intsalling the cai this morning and on the step where you have to remove an engine bolt for a support bracket i was having trouble removing the bolt itself. has anyone else had this problem, and if so what was your solution to fixing it?
