K & N Filter
Old Jan 23, 2013 | 02:37 AM
tnt008's Avatar
Default K & N Filter
I was just wondering if a K & N drop in filter into the stock air box is a waste of money? Yeah I know the change in performance will be minimal, if any. But what do you guys think?
Old Jan 23, 2013 | 02:49 AM
Team Desert Eagle's Avatar
I had problems with the last one that I used, it took out the mass airflow sensor by covering it with oil.
Old Jan 23, 2013 | 03:55 AM
tnt008's Avatar
Yeah, I did the same thing with the K&N CAI I had on my Lancer. But I know I had too much oil on it, or never waited long enough for it to dry. So, for that reason, I'm not overly worried. But thanx for the reply
Old Jan 23, 2013 | 04:39 AM
demp's Avatar
Gives minimal increase in performance as you said. Increases exhaust sound, but lets tiny particles through which can reduce your engine's longevity.
I put the drop-in on my 05 TJ, and after about a year I noticed a thread on another forum stating the dirt buildup. I look inside the engine side of my air intake and there is a very fine layer of dust.
Put a paper back in, cleaned the air intake tube, a year later not a spec to be found.
Old Jan 23, 2013 | 05:13 AM
Ryan0260's Avatar
Normally caused by over oiling the filter, and not allowing to dry before using
Old Jan 23, 2013 | 05:17 AM
tnt008's Avatar
WOW, really? So what your saying is that the K&N filter does not do as good job filter the air then the stock filter does. That comes as a shock to me.
Old Jan 23, 2013 | 07:45 AM
demp's Avatar
Its the nature of any high flow filter, not just K&N. To let more air through you have to filter less aggressively, as the filtering will restrict air.
Old Jan 23, 2013 | 07:57 AM
skippyrock's Avatar
I just changed to k&n and noticed a 2 mpg gain. Granted my stock filter was extremely dirty. Noticed no performance gain. And no change in the sound of the vehicle.
Old Jan 23, 2013 | 08:13 AM
Jersey_Devil's Avatar
U can't go wrong with a K&N filter..... There's a reason they are used in NASCAR, NASTRUCK, NHRA, INDY, and many other local racers use it.
Old Jan 23, 2013 | 08:15 AM
tnt008's Avatar
So this has led me to a new question or query. Looking for peoples opinions here. Is the amount of "dirt" being let through by the K&N to the point of being damaging to your engine?
As previously stated, I've had a K&N CAI on the Lancer for 8 years. Never an issue.
