kc or mopar mount? (pics included)
has anybody purchased the wire harness kit
in the link
http://www.wyckoff-chrysler-parts.com/20wroflimobr.html
its part number 82210507
For $79.35, seems a little expensive for the wire kit
in the link
For $79.35, seems a little expensive for the wire kitI have one, it is ok, but not worth that much IMHO (I didnt pay that for it)
It comes with the wires pre-wrapped in flex tubing, with all the terminations installed. it has a few fancy disconnect plugs(that you will need to assemble) in it, one disconnects the relay from the lights themselves, another disconnects the relay from the power sources & ground, the third is an empty socket, and is used to connect future relays in series with it (so multiple relays would all be controlled by one the switch, if you bought multiple harnesses with the same plugs)
I dont see these as necesarry, the regular old relay/switch setup works just fine without them and has for what? 50 years?
I can post a schematic if your really interested.
Well...i'm in the minority..
You're all nuts.
I like the KCs better - farther away from the hood and at a better position for aiming. Gives you clearance of the hood so you can really use them as spot beams.
You're all nuts.
