Killing Esp
Old Sep 28, 2007 | 07:47 AM
SLICKWILL's Avatar
Default Killing Esp
IM open to all and any ideas.... its getting to be to much... light flashes and i lose controll.. pulls to the right withe no brake or throttle response at all
ideas....
* something i herd about making a switch??
* pulling the plugs that go into the hub of the wheel i belive
* pulling a fuse??
* selling the jeep!!
i got to get this to stop im will to be a giny pig give me ideas
Old Sep 28, 2007 | 07:55 AM
nycauburn's Avatar
i saw a way to turn it off on another forum, the only thing is the lights will stay on permently. it is something like grounding a purple wire somewhere. sorry not much help. i think it is the same as another model jeep. But you really might have something else affecting you here that is causing it. i know your aware the steering wheel is the key, and it has to be dead nuts center. i was a bout a inch on the outer area from off and the esp kept going off. most have no issue what so ever, as long as your set up correct. i do have the issue on the curves or the clover leafs, there is a TSB for 4x2's hopefully there is one for 4x4's. other than that it has never gone off in any other situation.
EDIT: the funny thing is, it was posted by michealw. his avatar on all the other pages is an anti jk-forum logo, whatever.
Old Sep 28, 2007 | 07:59 AM
Dizzyliz's Avatar
ideas....
* pulling a fuse??
Wow- mine rarely goes off.
Only if I am driving like a bat outa hell.
Maybe your steering isn't quite aligned just so?
Old Sep 28, 2007 | 08:01 AM
merfsiu's Avatar
Did you recenter the steering wheel after the lift? When recentering my wheel, i noticed that it is possible to be 360 degrees off. In other words, if you recentered in the wrong direction, it can be a full turn off. On another note, it would be nice if there was a way to see what the steering wheel position sensor is reading. I dont know if its digital or just a variable resistor, but it would be nice to figure out a way to test it.
Old Sep 28, 2007 | 08:19 AM
MJS_Jeep_888's Avatar
IM open to all and any ideas.... * selling the jeep!!
Oh please - like you'd really get rid of your pet monster!?! I don't think so!
Hope this thead helps. P.S. If you ever need to search for 3-letter words (i.e., "ESP") try adding a wildcard: i.e., "ESP*" (without the quotes).
Old Sep 28, 2007 | 08:39 AM
Rubidonn's Avatar
Between the above post (one above this one) and the following link, looks like you should be able to come up w/something.
http://www.lxforums.com/board/showthread.php?t=44728
Old Sep 28, 2007 | 08:41 AM
nycauburn's Avatar
here is the write up from the Charger forums
EDIT: Ah beat me to it while i had a phone call
Old Sep 28, 2007 | 09:36 AM
SLICKWILL's Avatar
I KNOW IT JUST IS DRIVING ME NUTS... LITERALY
THANKS ILL TRY THAT
Old Sep 28, 2007 | 01:02 PM
BLKRuby's Avatar
Maybe you drive too fast for a 2 door on 37s?
Old Sep 28, 2007 | 01:06 PM
SLICKWILL's Avatar
IT HAPPENS AROUND 30 IF THATS FAST DAMN
