lacking in sand
Old 10-06-2012, 02:58 PM
greenrescue's Avatar
Default lacking in sand
I just spent the day wheeling in a variety conditions and was very disapointed in how my JK did in heavy sand. I have 35's and 4.88 manual. It seemed like no mater how I used the gas on sandy hills I would just dig in. Would lockers make a difference. My old TJ Rubicon would have eaten the same terrane up. I love my JK any suggestions?
I have the 30 up front and a little scared of lockers in the 30. I am planning a trip to Rubicon trail in
July driving from Indiana and I need to change a few things.
Old 10-06-2012, 03:46 PM
gunbo75's Avatar
Did you air down. If you Spin your tires Down you go
Old 10-06-2012, 03:51 PM
Rob 12B1P's Avatar
Yea it sounds like you need to let more air out. JKU's are heavy MOFO's.
Old 10-06-2012, 04:00 PM
Went from 35 down to 20.
Old 10-06-2012, 04:41 PM
TikiBob's Avatar
When I run in the sand I air down to 12psi. But that's at silver lake.
Old 10-06-2012, 04:45 PM
Bubbacon's Avatar
What tires are you running? Mt's arent the best in sand because they dig in and move so much sand... They have very aggressive tread patterns. Having the effect of 'digging in'. With mt's you have to air down... I recommend to about 18 lbs.
With at's you will do a bit better in sand because the tread isnt as aggressive.
Ever been to the beach and watch street pickups just run through the dry sand with no problem... Not running aggressive tread tires. Run that same line in mt's at street pressure and you can dig to china :-)
Old 10-06-2012, 04:48 PM
nvertflyer's Avatar
i run sand at around 3 to 5 psi on beadlocks...20 is way too much,next time air down to about 12...that should work a lot better for you without worries on a non beadlock wheel
Old 10-06-2012, 08:58 PM
4-Lo's Avatar
In sand, it's all about running the lowest pressure you can get away with. I've had luck with 12 in the past.
Old 10-06-2012, 09:30 PM
rb1boxer_3's Avatar
Hmm I run about 25 dd but I have 1350s and it isn't bad in sand I stay in 2 wheel and I have the nitto MUDs go down around 14 or so psi should be good.
Old 10-06-2012, 10:33 PM
powrsurg's Avatar
Bingo, this is the first question I would have asked. WHen on the sand Im down to 12 - 15 psi.
Lockers would help certainly.
Quick Reply: lacking in sand
