lca install
Old Apr 11, 2013 | 02:19 AM
aaronstephen's Avatar
Default lca install
This weekend I will be installing my metal cloak lca's and was wondering if I can do the install workout jacking up the Jeep?
Also, would you recommend just using a ratchet strap to move the axle forward to fit the lca's since they will be slightly longer than stock?
Old Apr 11, 2013 | 03:24 AM
aldaman's Avatar
You can install the LCAs with all four tires of the jeep still installed and the Jeep on the ground. However, using a floor jack to slightly lift the front end at certain areas will help you align the control arms with the bracket so that the bolts can go in. I was able to install my arms w/out using ratchet straps using the floor jack method...
Look up the link on Project JK "do it yourself front end alignment" there's a write up there showing steps on installing the control arms...
Old Apr 11, 2013 | 03:33 AM
Oh cool, thanks. I'll definitely look it up.
