Leaking Transmission Cooler Lines Replacement
Had my second set replaced by warranty this past friday.
After taking a good look, I see there is no support from the Tranny all the way to the raditor. I can see the crimp on the hose loosing after several bounces. I was thinking tye-wraps can help stabilize the lines if I can find a place to secure them to. It may help prevent the leak.
What do yo guys think?
Does yours not have the black plastic line attachments? They should not hang loose from the back on the tranny.
With all the snow on the street, I did not take a good look. In a few months I'm at seven years. They will not be covered any more. Hopefully last time they leak. If they do I will definitely be copying your fix. You did a nice job.
I didn't remove the lines. Just was laying on my back for a while on a creeper. I used a small dremel wheel and cut a slit on each side. Prying off the cap was a little bit of a pain but the lines under them are cushed by the rubber hose.
I lost about a half a quart of fluid in a drip pan when the lines came off.
I had the the problem with my trans line,I removed the line and took it in to a shop that makes and repairs hydraulic lines,cost less than $20 and they repaired it while I waited, took less than 15 minutes,repaired line looked better than the factory one.the line is not that hard to remove just be careful that you don't loose the clips that hold it in.
