Learn me on stock springs
Old Mar 14, 2014 | 10:49 AM
bludevlsi's Avatar
Default Learn me on stock springs
So i keep seeing and hearing people asking for numbers on stock springs. What's the difference in numbers and are some better than others?
Old Mar 14, 2014 | 11:02 AM
Croce's Avatar
The higher the spring # is, the stiffer they are. i think 19 front and 60 rear are the stiffest.
Old Mar 14, 2014 | 04:04 PM
karls's Avatar
With the exception of 10A Rubi springs, they're different part numbers and end in 06-09 (front and rear).
Old Mar 14, 2014 | 04:13 PM
Croce's Avatar
Is that for all rubi years? i got some rubi take off springs but the ended in 19/59. think they were off a 09
Old Mar 14, 2014 | 04:31 PM
karls's Avatar
No sir, 10A's only. All other models (to my knowledge) will follow the 19/60 guidelines.
Old Mar 14, 2014 | 05:27 PM
catahoula's Avatar
If you are thinking about changing out also compare your existing so that you are not wasting your time. I believe on average per number can net close to 1/2 an inch. If you want to save some money you can get some used Rubi shocks. It would help with the ride, at least it helped mine.
Old Mar 29, 2014 | 07:31 AM
webejeepin's Avatar
Just a question are the Rubicon 19/60 the same as the 10A 06/09? Or are the 10A coils more sought after for their spring rates?
