LED help
I have a 2013 Wrangler Unlimited Sahara that I installed Axial front smoked LED side marker lights and LED front Smoke turn signals, purchased from Extreme Terrain. Both seemed to have no problems. I then installed Axial LED Halo tail lights and the two tiny side LED diodes and the halo itself stay on, even when the vehicle is not powered on and nothing is left on. Further, it caused the new front side marker lights to be lit as well as the marker lights that are inside of the Morimoto 3 Bi-LED lens. I can't figure out a cause and have my battery disconnected to avoid it being drained. The new lights all look great and I very much would like everything to work as intended. Please advise.
Welcome to the forum BTW. LED tailights non-factory are the biggest pain in the arse that I will never care about them. Seems like you have to buy the expensive ones to make them work and I see zero value in LED tailights (just MHO). Remove them and go back to the seller. They were obviously not plug and play.
