Lessons learned while modding (warning---long post)
Old Jun 8, 2011 | 05:33 PM
  #31
JKSLEEPR's Avatar
Good advise, thanks for summarizing and the post.
Old Jun 8, 2011 | 05:52 PM
  #32
weebus's Avatar
Default lessons
great post it should be given out at new jeep purchase
Old Jun 8, 2011 | 06:11 PM
  #33
jhb26len's Avatar
Thanks Paul, great post, really helpful to us newbies out here
Old Jun 9, 2011 | 03:29 AM
  #34
Paul R's Avatar
Originally Posted by DJSJK50
This is real cool, thank you for writing it. 2 targeted questions.
On the lift, if you do have a puck space lift. When it comes time for the life (I too will probably go OME 2"), Do you remove the spacers?
Is the best stuff, always the expensive stuff? Or, is this, again personal preference.
I am not trying to start anything, just trying to learn. I am going the overland wrought as my other hobby is photography and I just want to get there. If I can go around a rock, I will.
I will be removing the pucks to install the lift and then see how level it sits. If it is not as level as I want, I can put back in selected spacers to level it out.
As far as expensive stuff being the best, as a general rule you usually get what you pay for, but there are always exceptions. The part that I found where quality and features is most closely related to price is bumpers. Cheap bumpers usually do not have as good a powdercoat on them and can rust more quickly, and they usually do not have the features of the more expensive bumpers (swing with tailgate, mounts for jerry cans, etc...). Of course, as with everything else, there are exceptions.
Paul
Old Jun 9, 2011 | 03:30 AM
  #35
Paul R's Avatar
Originally Posted by evilclown
Informative post!!!! How much to write my college paper???
$10,000. I got mods to buy
Old Jun 9, 2011 | 03:33 AM
  #36
Paul R's Avatar
Originally Posted by jimk403
Good read, but I disagree with one point. The JK wheels fit tight around the hub, but are not hub centric. Notice the lug nuts are kind of countersunk into the wheel? This is what centers them, not the hub itself.
Feel free to disagree, then go out and look at the wheels on the nearest dually. My previous vehicle was a Ram 3500 dually, and those lug nuts were flat with a washer, and the hole in the wheel for the stud was oval. That wheel fit very tight on the hub because the hub centered it, not the lug nuts.
Sorry, but I do disagree. The stock wheels are hub-centric. But, just because the wheel is hub-centric does not mean you don't need acorn nuts. The wheel can still rotate around the hub and the acorn nuts align the wheel with the lugs. They also provide a second layer of strength to the attachment.
Paul
Old Jun 9, 2011 | 03:54 AM
  #37
scotty6336's Avatar
One thing to add...Cheap, Big, Reliable...pick 2
Old Jun 9, 2011 | 03:55 AM
  #38
Paul R's Avatar
Originally Posted by Joisey
GREAT READ!!!!
Well said, I wish i would have went rubi from the start.
That being said I built my d30 to the hilt and beat the piss out of it. Its still holding strong w/ 35's
I had a D30 on my 2007 Sahara and ran 35" Toyo MTs (about the heaviest MT out there). I upgraded the axleshafts to chromoly and put C-gussets on it. I did not sleeve the axle since I don't do rock crawling. I never had any problems. The D30 in the JKs is stronger than the D30 used in the previous generation Jeeps because it is high-pinion. If you are not going to rock crawl and don't plan on going bigger than 35's, the D30 will do fine. But, If you are thinking 37's or plan on hitting the Rubicon trail and such, the 44 is a better choice. One other point...the D44 has more options for regearing and can handle higher ratios than the D30 can. Again, not a problem unless you are going big tires.
Paul
Old Jun 9, 2011 | 04:02 AM
  #39
PhantomRescue's Avatar
I'll chime in as well, nicely written and seems like you thought a lot of this out before just spewing a bunch of words on a page. This will be a good place for newbies to have a look and make some more 'informed' decisions before spending hard earned money on their JK! Well done.
Old Jun 9, 2011 | 06:59 AM
  #40
RescueGreen#3's Avatar
Great post.
I wish I would have read this years ago. One thing for new jeep owners is to know, once you make the smallest mod, it affects other components & those other components will affect their geometry and more mods will happen to adjust the other mods.
After thousands of dollars, sometimes I wish that I would've just added MT tires and stopped there. But... Just Empty Every Pocket creeps in
