Lets say you lost a inch?
Old Mar 10, 2013 | 05:33 AM
  #21
mtb856's Avatar
I'll be honest, with the title of this thread I wasn't exactly sure what I would find when I clicked on it.
Old Mar 10, 2013 | 06:09 AM
  #22
clemons's Avatar
Originally Posted by mistasparkl
mmmk. When I find some "harm" done, I'll be sure to let you guys know.
Gaps between the frame and body, gaps between bumpers and body. Higher cog.
Old Mar 10, 2013 | 12:13 PM
  #23
Christarp's Avatar
Wouldnt you have higher cog from any sort of lift? But moreso from a suspension lift because then the frame is being raised as well? I'm not really a fan of body lifts simply because of the way they look, but if I needed something small like an inch I may consider it.
Old Mar 10, 2013 | 12:35 PM
  #24
Fugg it's Avatar
climb underneath and look, there is already gaps between the frame and body on ur stock jeep. it only increases the gap. u have body mounts between ur frame and body already.
Old Mar 10, 2013 | 03:01 PM
  #25
RyanW's Avatar
Having seen body lift bolts shear in an accident as cause catastrophic damage that normally wouldn't have happened, I'll never install one on my own vehicle ever again.
Running a 1" spring spacer won't hurt anything. Your lift was designed to sit at that height so none of the components will see any difference. It's a lot cheaper than buying springs, which will simply net you the exact same outcome.
Old Mar 10, 2013 | 03:25 PM
  #26
clemons's Avatar
Exactly. Why increase it more? Sorry to the op for the thread jack.
Old Mar 15, 2013 | 09:57 AM
  #27
kfxbryan's Avatar
Has anyone used a simple coil spring compressor to make the job alittle easier to put the spacer pucks on top?
Old Mar 15, 2013 | 10:04 AM
  #28
Wood82ABN's Avatar
Agreed. Installed body lift... Love it!
