Lets talk Speedo Correction!?
Old Oct 1, 2007 | 01:28 PM
CarFanatic's Avatar
Default Lets talk Speedo Correction!?
ok is there anyway besides the dealer flash for 32" tires to correct the speedo for bigger tires 33-37 etc?? I heard someone used a procomp programmer and it worked, but I dunno how true that is?
Old Oct 1, 2007 | 01:41 PM
wayoflife's Avatar
JK-Forum Founder
Your dealership can only flash your computer up to 32" tires. Beyond that, they will not be able to help you out. I have just used the ProComp Accu Pro on my JK and will do some testing against my GPS in a few minutes. I will post my results shortly
Old Oct 1, 2007 | 01:48 PM
CarFanatic's Avatar
ya let me know if that works! All thought 200 bucks just for a tire flash kinda sucks...
Old Oct 1, 2007 | 01:50 PM
4JEXEP4's Avatar
BUMP BUMP AND ANOTHER BUMP
Old Oct 1, 2007 | 03:06 PM
wayoflife's Avatar
JK-Forum Founder
Well son of a gun - this thing actually WORKED!!!!
Seriously, using the Pro Comp Accu Pro, I was able to set a specific tire size down to a 1/4" (my worn down 315/70R17 measuered up to 33.5") and set the gear ratio to 5.13's which is what I have on now. And, after doing a series of tests and checking it against my GPS, I can tell you that my speedometer is actually reading dead on now. Need I say, if you're looking to get your speedo calibrated to match your new bigger tires, this thing will do the trick.
I will try to get a more thorough write-up on how to use this thing as soon as I can.
Old Oct 1, 2007 | 03:17 PM
forumonlooker's Avatar
Sort of a thread jack, and you can delete if necessary, but I was wondering if the computer speedo is set to optional equipment, a base number for all, or if it comes programed accordingly to x/saraha/rubicon?
Old Oct 1, 2007 | 03:23 PM
wayoflife's Avatar
JK-Forum Founder
If you are refering to the JK computer, it is set for the specific size tire and gear ratio of your Jeep.
Old Oct 1, 2007 | 03:26 PM
FzyPchz's Avatar
WOL, who's selling the Pro Comp Accu Pros? Thx.
mikeyfl's Avatar
awesome news. someone needs to buy one that can be rented out.
Old Oct 1, 2007 | 03:33 PM
FzyPchz's Avatar
I was thinking the same thing...$200 is alot of money (and for me, it would basically be a one time use since I don't plan on going any larger in tire size).
