Leveling Kit
Leveling Kit
So, I have a 2" Mopar lift with 33" tires and I have added the AEV front and rear bumper. What will a leveling kit do for me? How will it impact my lift, ride, etc? I know next go around I want to go bigger...35s. Will adding a winch be adding too much weight and take away from my 2" lift? I was thinking a leveling kit 1" would benefit me. Who makes a solid kit and how hard to install?
The front pinion will tilt up, which lowers the caster a bit, which causes flightier steering. Both axles shift to one side. Brake lines are stretched tighter. Swaybar angles are steeper. Driveshaft angles are steeper.
Look at the components in some of the more complete 3-3.5" lifts and ask yourself why they are included. Or you could open the faq's and read the section on recommended components for various lift heights. (everyone will have a different opinion on what is needed at any particular height, so just gather the info and decide for yourself)
If you're worried about the front of your jeep sagging from adding a winch, place about 100lbs on the front bumper and see how far it sags and that will tell you if you think you need that extra lift or not.
