Leveling kit question
Old Sep 17, 2012 | 11:26 AM
856kid's Avatar
Default Leveling kit question
From what someone told me. When you lift your jeep it will start to bring your tires closer to the body. Would this happen with and 1.5" leveling kit. Or was I given bad info.
Old Sep 17, 2012 | 12:10 PM
aldaman's Avatar
...The only time your tires will come closer to the body is when you start running larger diameter tires on an unlifted jeep, hence the need / reason to lift your Jeep to provide the clearance. For example, if you run 35" tires on an unlifted jeep your tires will be closer to the body. But when you install a lift kit, the taller springs or coil spacers will give the opposite effect.....another example would be if you lift your jeep and run stock tires your tires will be further away from the body........
Old Sep 17, 2012 | 12:16 PM
aldaman's Avatar
Here's a visual for reference
STOCK SUSPENSION
LIFTED
Old Sep 17, 2012 | 12:22 PM
xcoaste's Avatar
When most lift a Jeep they do so for larger tires. If you increase the middle number of the tire size (33x12.50x17) they will be wider, and closer to the frame. I don't know of any other reason you would see this just because you lifted your vehicle.
Old Sep 17, 2012 | 12:30 PM
aldaman's Avatar
I got this from another thread. Notice the distance / space between the 35" tires and the fenders....
Originally Posted by TonyJeep75
Sorry, not duratracs, but Nitto TrailGraplers. Snug as hell. If you turn the wheel all the way it hits the plastic 'skid-plate' under the front bumper. My 2012 with 3.73 gears still turns them with no problems. I wouldnt recommend this long term, it will rub if you hit a big bump. My RK 3.5 lift is in the mail (I hope).
This is my '08 JKU lifted on 35s
