Leveling and spacers
The first thing that jumps out to me is you have cam bolts installed in the lower control arms (axle-side bracket). That may be something that you want to read up on. It’s just my opinion that those are the worst caster correction options we have. I don’t trust them at all. That is not to say they will give you problems, but if you get in to off roading much, you might want to look at a cam bolt delete kit which just fills in the holes in the axle bracket and allows you to use a normal bolt again, and select a different means of caster correction. Not trying to fear monger, I just noticed them immediately.
Also, it looks like you have a zerk on top of the ball joint in one of those pictures….kinda hard to tell though. Maybe that is just part of the tire I’m seeing behind it giving the illusion something is on top of the BJ. If there is a zerk, someone has replaced the BJs on that along the line as the factory BJs aren’t serviceable.
Factory tie rod
Factory drag link
Factory tie rod
Factory drag link
Thank you for pointing out the cam bolts. I was not aware. I am planning to plunk down for some CORE 4x4 level 3 adjustable lowers to correct caster. I will remove the cam bolts during the install. I will check out the BJs and see if there are indeed zerks. I do not believe this is the case.
must just be an illusion caused by some raised lettering on the tire behind it then. If those are factory BJs, you should at least start budgeting for some as they are a common issue on our modified JKs. You can read up a bit on em. Although no perfect options, Teraflex seems to be one of the better options lately due to warranty. Rare Parts are pricey, but probably the last BJs you'd ever have to replace.
OK. So my mystery is yet unsolved. If this is an older OME lift with OME-tagged coils all 'round, why would there exist what appears to be front coil spacers? The minimum lift with a set of coils and shocks would be 2", yes? This JK does have a pronounced rake to the front...
If you wander around OME's website, you will find a big table of like 15 or 20 different coils for the Jeep JK. They are listed by rate and application (2dr/4dr/Gas/Diesel/load rate/etc). That the box says 2" lift is meaningless, what matters is the coil rate and what model JK you put them on. (My 2" front OME coils were classified as Heavy Duty, and gave around 3.25". Since I had a heavy front bumper and winch, the shop I ordered from suggested Medium duty rear coils to go with the HD fronts)
added info for the link to arb coils below
The rear coils are tagged OME620, which I have referenced as 2" JKU rear coils. There exist no spacers in the rear.
The front coils are tagged OME19. I can find no reference to this part number except Dakur leaf springs.
I do have an ARB front bumper, heavy front skid plate and Warn Powerplant 9.5 on the front. Sounds like I will need to contact ARB/OME and look into a heavier spring.
Looks like they moved stuff around on their site again.( ARB USA - Guides - Vehicle Application Guides - Jeep)
2619's are 4dr front Heavy Load (89-180 lbs)
2620's are 4dr rear Heavy Load (660 lbs)
I didn't see it listed, but they used to have a '+40' coil that was around a 4" lift. That might be an option if you want a taller OME coil. Or, MetalCloak coils are taller than stated spec - I'm around 4.5" with their 3.5" coils (but folks with heavier rigs indicate that 4" is more normal).
CBJeeper (03-31-2019)
