Which Lift?
Old Jul 21, 2011 | 01:07 PM
  #21
Delux2769's Avatar
Originally Posted by wecf
Currie 4" w/37's
Which Currie 4" is that? If it's the 4" Standard then I really like it, if it's one of the other 2, at $2k+ retail, Then it might be a little expensive for me.
Thank you for a lift to add to my list though
Old Jul 21, 2011 | 01:34 PM
  #22
Ryan0260's Avatar
Have you looked at the Rusty's lifts? You can get their basic 3 1/4" lift with front and rear adjustable trackbar for $550. It can be upgraded easy and with your 1" bl would be plenty to clear 37's
Old Jul 21, 2011 | 01:48 PM
  #23
Delux2769's Avatar
@ Ryan0260 - I'll look into Rusty's kit. You suggested upgrades, what ones were you referring to?
Thank you
Old Jul 21, 2011 | 02:16 PM
  #24
Ryan0260's Avatar
At a minimum I would do a set of jks disconnects, extended brake lines, and a 3/4' spacer to keep it level especially if you add a bumper and winch. From there can add in control arms as needed.....best part is you can build it in stages
Old Jul 21, 2011 | 02:19 PM
  #25
Delux2769's Avatar
What's the benefits for the Discos? I've seen alot about them, but not heard any information on them and their uses.
Old Jul 21, 2011 | 02:29 PM
  #26
Ryan0260's Avatar
It allows you to disconnect the swaybars for better articulation of the suspension. It is a must have item to go offroad because your swaybars limit the amount of suspension travel of the axle
Old Jul 21, 2011 | 02:48 PM
  #27
Vic's Avatar
Vic
Somany to chose from, I'm also undecided on what to go with .
Old Jul 21, 2011 | 03:18 PM
  #28
Gcollura's Avatar
A few months ago I helped Deviljeep install a Rough Country 4" x series lift so he could run 37s. This lift came with everything he needed and worked great and was within your budget with plenty of room to spare. He is also running the xrc armor front and rear so you can get a good idea of what to expect from him. Do a search for him on here and check out his pictures.
Old Jul 21, 2011 | 07:32 PM
  #29
Delux2769's Avatar
@ Gcollura - Yes, Deviljeep was the inspiration for my jeep project. So with this kit, you're saying nothing extra will be NEEDED to run 37's?
Old Jul 21, 2011 | 07:55 PM
  #30
ride2099's Avatar
most of kit no need extra to run 37 you need 3.5 or 4" lift and you can run 37" all extra part is just to gain stability confort and durability you can just put coil spring and shock with track bar bracket or no bracket with ajustable track bar and you all go im not saying that gonna be better than facotry but you can put 37 if that is you goal
