Lift Install
I put mine on and I found that in addition to using a floor jack to raise and lower the axles, if you use a bottle jack to lift up the opposite side of the axle that your working on in tilted the side your working on down just enough more to slide the springs and everything back in. especialy on the front axle. I did not have to remove the drive shaft as some of the insructions said. for the most part I followed wayoflife's write up on the install of the terraflex bb. good luck
Take your tranny skid and cross member off, only a few bolts, and it will allow you enough droop. Just make sure your frt is jacked really high so you can let the axle down far enough on the jack to load the springs, if not you'll have to re-jack the frame and if you only have one floor jack it's gonna be time consuming. If you have spring compressors that'll work to , but it's time consuming also if you don't have an air ratchet.
Disconnecting the swaybar and shocks should be a no-brainer. You still have to have the jk jacked high enough to allow the frt axle to droop enough underneath the frt, Am I the only one who gets this
I also speak from experience
