Lift Problem Need Help!!
Old Oct 4, 2009 | 06:16 AM
cunningwolf09jk's Avatar
Exclamation Lift Problem Need Help!!
Yesterday I installed a 2.5" teraflex coil lift and when I was driving home my ESP/BAS light and the ESP/TCS light came on and stayed on. Is that normal? What can I do to get them to turn off (maybe a rear adj. track bar)? thanks for the help.
Old Oct 4, 2009 | 06:19 AM
wiredawg_mg's Avatar
Did you recenter your steering wheel?
Just a little off freaks out the computer
Old Oct 4, 2009 | 06:56 AM
Robar's Avatar
Q: How do I recenter my steering wheel?
A: To re-center your steering wheel, use a 15mm wrench to loosen the 2 nuts on the turnbuckle on your drag link as shown in the pic below. Then, rotate the turnbuckle clockwise or counter clockwise as needed while a friend watches the steering wheel (or you periodically check on it yourself) go back to center. Once re-centered, secure the nuts and take it for a drive to check your steering wheel. This may take a few tries to get it on 100% but that’s all there is to it.
Old Oct 4, 2009 | 07:47 AM
dpoelstra's Avatar
X3
It doesnt take the wheel to be off center much to freak out the 'puters...
Old Oct 4, 2009 | 08:07 AM
wildandwillin's Avatar
Thats correct, did you fix it?
Old Oct 4, 2009 | 08:17 AM
ben1284's Avatar
mine did that too after i installed my frnt. adj. trackbar. centered the steering wheel and everything is fine now.
Old Oct 4, 2009 | 08:35 AM
nthinuf's Avatar
Here is the full DIY Alignment write-up. Good info to browse through.
http://project-jk.com/jeep-jk-write-...-end-alignment
Old Oct 4, 2009 | 12:34 PM
I recentered the steering wheel atleast it looked good to me but the light stayed on do i have to drive it a long distance for the computer to sense it? could something else cause this problem?
Old Oct 4, 2009 | 12:44 PM
mkjeep's Avatar
Check your abs wires , one could have been damaged or unplugged during install.
Old Oct 4, 2009 | 01:19 PM
I have had it stay on for a while after re-centering. If it is still on after driving it for a day then it is time to find another reason.
Good Luck
