Lift question
Old Jul 23, 2012 | 08:52 AM
JE8154's Avatar
Originally Posted by Willis19
I forgt to say that I have jks disconnects and a rock Krawler frot track bar and I'm gonna order the rear soon also...
I might switch to the Evo plush 3" coils and if I do so should I change my Tera flex shocks ?
If the evo coils only give 3" of lift on a 4 door I probably wouldn't waste my time with them since that is about the same as what the 2.5" teraflex lift nets. If they net more than 3" you should get longer shocks. You should see more on a 2 door.
Old Jul 23, 2012 | 10:05 AM
AirBorne82's Avatar
Originally Posted by JE8154
The guy currently has a 2.5" lift and wants to go to 3.5". How would rubi springs get him there?
Maybe I did a poor job of explaining..
For clarity, "rubi" springs really aren't the issue. The reason I suggested he get the springs and shocks from a 2012 rubi was more about the shocks than the springs.
What matters is the last two digits of the tags on the springs. Most JK 2DRs (which the OP has) have springs with the last two digits that are 14 in the front and 55 in the back or something close to that. Most JKUs, regardless of whether or not they are a rubicon, have 17/58 or 18/59 combinations depending on how they were equipped. Typically, going from 14/55 to 17/58 or 18/59 increases the height of a JK 2Dr by an inch or more. SOme have even said it was over 2 inches. My personal experience was about 1.5 inches.
Old Jul 23, 2012 | 11:44 AM
JE8154's Avatar
Maybe you're in the wrong thread or something. I don't get why you would suggest anything having to do with rubicon take off suspension parts if the guy is trying to get a proper 3.5" lift. He doesn't want a 2 inch lift or a 1.5" lift he's looking for what components he needs to get aside from the springs to change his 2.5" teraflex lift into a 3.5" lift that doesn't drive poorly.
Old Jul 23, 2012 | 11:52 AM
AirBorne82's Avatar
My apologies.. I just realized he has 2.5" coils, not 2.5" spacers.. That of course makes everything I said worthless to him.
Old Jul 23, 2012 | 12:52 PM
Willis19's Avatar
Haha it's cool guys thanks for the help tho
But anyone have suggestions on what to do
Thanks
Old Jul 23, 2012 | 06:12 PM
JPJKU's Avatar
Put spacer is cheapest way but spacer is not compress, it is same as that moved coil mount downward Thus stroke is same as previous one.
If you want go harder terrain, get other coil is better.
Coil lift vs spacer lift is deferent purposes.
Spacer is just raise it to get more ground clearance or to adjust height for looks.
Coil lift is not only raise it but also get more stroke for traction.
However more than 3.5" needs lot of parts, money and time.
All link and arms will be short then both axle will move to either side, prop shaft start vibrates, brake lines will too short and tends to wandering steer and death wobble will happen in worst case due to caster will change upright.
To solve those issue, needs money and time.
Since in my 4x4 experience.
Old Jul 24, 2012 | 02:28 AM
JE8154's Avatar
Thanks
Got a budget to work with?
You're looking at coils, front break lines, front lower adjustable control arms, rear upper control arms, longer rear sway bar links, longer shocks, and I think one or both drive shafts as well on a 2 door.
Old Jul 24, 2012 | 05:54 AM
Willis19's Avatar
Can I put jks quick disconnects on the rear also ?
And I was going to put a long arm upgrade on it once I got coils. But I didn't think about the drive shafts and those are 500 a peice
Old Jul 24, 2012 | 07:13 AM
Atch's Avatar
Yeah u can put them on the rear but there is no need to disconnect the rear
Old Jul 24, 2012 | 06:41 PM
Willis19's Avatar
Ok well what brand should I get if I don't need to dicinnect them ??
