lift question
Old Sep 6, 2013 | 05:58 AM
Loose Screw's Avatar
Default lift question
can you use stock 18 inch wheels without spacers on 2.5 lift if you put link bars on inside of swaybar?
Old Sep 6, 2013 | 06:03 AM
KurtieR's Avatar
Yes you can, I ran 33s on stocks with a 3inch lift no problem.
Old Sep 6, 2013 | 06:10 AM
what brand lift did you use
Old Sep 6, 2013 | 06:27 AM
KurtieR's Avatar
I chose bds. I loved it, awesome ride and stood up to some serious abuse
Old Sep 6, 2013 | 07:55 AM
does bds move the sway bar down if so any problem with stock exhaust
Old Sep 6, 2013 | 08:28 AM
Matthewd5's Avatar
I've got a 2 door 2012 with a 3" bds lift, I went for the quick disconnects plus the fox shock upgrade and I live the ride and the way it takes on just about anything off road
PlUs I added two fairly heavy bumpers and you can't tell the difference
I have 285/70/17 Duratrac's
And I'm adding a winch next week
Matthew
Old Sep 6, 2013 | 08:40 AM
SabrToothSqrl's Avatar
Default Bds
My 2012 Rubicon came to me with a 3" BDS lift on Foxx Shox
the rear sway bar is lowered about 1", but I may at some point move it back up, and use longer links.
I can't say enough about this lift and the ride.
I replaced the brake line relocation brackets (1/2 assed in my opinion) with longer brake lines.
Ride is PERFECT, ESP works just fine.
I have the 35" equivalents on a 16" wheel. 315? I'm not sure, as it came w/the jeep, but I know they are 34.5"
at some point I may move to Rock Krawler suspension arms, but I'm very happy w/this lift. I never drove a stock JK, but this thing rides better at 80 than my TJ did at 40.
Old Sep 6, 2013 | 10:38 AM
Matthewd5's Avatar
I have a 3" bds lift on my two door JK and I got the optional quick disconnects
Maybe that would help you out?
Matthew
Old Sep 7, 2013 | 04:07 PM
KurtieR's Avatar
The sway bar links do not rub on the wheels, I was concerned as well but it worked perfectly.I actually picked up a rubicon express lift and some fox shocks and it's a fantastic combination
