Lift questions
Old May 1, 2012 | 07:20 AM
Rock Krawler Suspension's Avatar
Former Vendor
If you are interested in our Rock Krawler Systems, any 2.5" system would fit perfectly for you and they are all easily upgraded to even a long arm system!
Good Luck with your build.
RK
Old May 1, 2012 | 01:28 PM
TheGrimJeeper's Avatar
Originally Posted by jlknights61
I have a 2dr with a manual transmission. Ok, I understand that 35" tires will cause increased stress on those drivetrain parts, but I would not necessarily have to upgrade these right away, the extra strain will just cause them to fail earlier than if there was no modification correct?
That is correct, obviously the more rough you are with it, the shorter it will last. My main concern is that the 3.73 gears (i have them also) are gonna be sluggish so I'm on the fence between 33's and 35's
are you able to upgrade this when replaced to correct this from happening in the future, or is it something you will always have to deal with?
When you upgrade your driveshafts you shouldn't have to worry about any problems because of the improved angle.
Old May 1, 2012 | 01:44 PM
jlknights61's Avatar
Ok that's what I thought. Yeah I'm a little worried about the gearing as well I guess i could always re-gear in the future if it was to sluggish. Btw since you said you were looking at a 3" lift also, I spoke with the rancho rep on this forum and they are releasing a 3" sport lift today, it should be in the large online stores within a month, and it is also eligible for their shock and awe promotion.
