lift ?'s
Old Feb 9, 2010 | 07:09 AM
Default lift ?'s
i found a guy local selling his lift for pretty cheap ($250)
its this kit here: cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=380204859443&ssPageNam e=STRK:MEWAX:IT"]http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=380204859443&ssPageNam e=STRK:MEWAX:IT
4" Rough Country
i was wondering what all else would i need to add to it?
i was thinking dual steering stabilizer,quick disco's,and adjustable control arms.
which control arms would i need, ive read that some people use different 1's
some just front upper and rear lower, and vice versa?
the kit has trackbar brackets, but would it be better to have an adjustable trackbar?
Last edited by wayoflife; Feb 9, 2010 at 07:17 AM. Reason: please do not post direct links to ebay
Old Feb 9, 2010 | 07:19 AM
wayoflife's Avatar
JK-Forum Founder
4" of lift is a lot of lift and if you have an automatic, you're gonna want to get a new front u-joint style drive shaft. adjustable front lower control arms to set your caster is also a bare minimum in my opinion. also, while this kit comes with a front track bar relocation bracket, i would recommend that you get a new adjustable track bar. being that you will be installing an new dropped pitman arm, you will need to keep the relocation bracket. longer brake lines wouldn't be bad to have either.
Old Feb 9, 2010 | 07:27 AM
FlameRed's Avatar
I'd look at brake lines and bump stops if they're not in the kit. That should give you what you absolutely need.
Adj track bars vs relocation brackets are, in theory, independant. The bracket helps correct geometry by keeping the bar more parallel with the axle. The adjustable bar helps to recenter the axle. Reality is that the bracket may correct things so that the axle is centered enough.
If you have an auto, you will have the driveshaft issues, you can search on that, there's plenty to read on the subject.
So...
-Adj track bars: put the kit on, if the axles are so far off you can't stand it, then get the adj TBs you need.
-Adj CAs: put the kit on, if it drives like junk, then spring for some CAs.
-Brake lines..Yes, stock are too short
-Bump stops...I think those shocks have integrated bump stops??
-Drive shafts...put the kit on, and drive it until the shaft starts failing, then get a new one.
Old Feb 9, 2010 | 07:39 AM
i have a 6spd, i forgot about brake lines, it says it has brake line brackets, but i would rather just do new lines
i think the rc shocks have integrated bumpstops
Old Feb 9, 2010 | 07:42 AM
wayoflife's Avatar
JK-Forum Founder
ah yes, i forgot about bump stop extensions. you should pick up a set of those. as far as the shocks go, they do come with bump stops but, i would not recommend they be used in place of actual bump stop extensions.
so..front lower to adjust the caster, what about for the rear, i saw a pic of a green jeep w/ a lift and the rear wheels was closer to the runningboards, how do you get rid of that? rear upper or lower control arms?
Old Feb 9, 2010 | 07:44 AM
wayoflife's Avatar
JK-Forum Founder
you would need both to reposition your axle. if you just installed lowers, you would change your pinion angle and that's not good. honestly, it's not that big of a deal that your rear axle shifts forward a bit. all you need to do is trim the corner of your pinch seam. as far as running boards go, i personally wouldn't run a set as they would do nothing to protect your rockers.
Old Feb 9, 2010 | 07:53 AM
i was looking into getting a set of rock sliders, so the running boards wont be on there much longer anyways
so basically heres what i will need to add:
steering stabilizer
quick disco's
adj. trackbar
longer brake lines
bumpstop extensions
correct?
Old Feb 9, 2010 | 08:01 AM
wayoflife's Avatar
JK-Forum Founder
steering stabilizer
quick disco's
adj. trackbar
longer brake lines
bumpstop extensions
correct?
sounds about rigt to me only, i personally wouldn't bother with the steering stabilizer. the factory one is fine. at least, that's all i ran with my 37" of lift and coilovers
Old Feb 9, 2010 | 08:03 AM
ok, good to know, i only need to add it, if i need it
