lift ?'s
Old Feb 9, 2010 | 08:09 AM
1 more thing, front and rear adjustable track bars or just front?
Old Feb 9, 2010 | 08:12 AM
wayoflife's Avatar
JK-Forum Founder
you should be okay with just a new front. it will allow you to recenter your axle exactly. the rear's not as big of a deal and the relocation bracket should do the job well enough.
Old Feb 9, 2010 | 08:20 AM
sorry, to keep being a pain in the ass..lol, i'm still new to moding jeeps, but i want adjustable front lower control arms right? and in the lift kit it says something about cam bolts...what are they for?
Old Feb 9, 2010 | 08:27 AM
ej428bj's Avatar
The cam bolts are for the trash, the new adjustable lower control arms do the same job as the cam bolts are designed to do, but youll be happier with the arms. The cam Bolts are to help adjust the front axle some on the alignment rack with the lift, but with the new arms you dont need and dont want to use them.
wayoflife's Avatar
JK-Forum Founder
LOL!! no problems. cam bolts will allow you to set your caster too but, in order to do that, you will need to make slots in your control arm axle mounts. while this does work and would be fine if you were to just drive your jeep on pavement, off roading puts a lot of stress on these bolts and causes them to come loose. once loose, they they slide around, change your alignment and be a real problem. adjustable lower control arms are more expensive but they are the better solution.
Old Feb 9, 2010 | 08:34 AM
basically pitch the cam bolts and get the adj. front lower arms
i found a set from rock crawler for $224 and daystar has a set for $259
Old Feb 9, 2010 | 09:12 AM
wow..i'm gettin a hell of a deal...lol
the lift for $250
and now he has the aev snorkel with both tops and his cut hood for my stock hood and $125-150
