Lift springs and spacers
Old Nov 20, 2009 | 07:26 PM
raymond324's Avatar
Default Lift springs and spacers
hello i have a 07 4door wrangler and i put a 2" spacer lift w/shocks from rough country now that it's in i want to go even higher. my question is can i keep my 2" spacers in and add four new lift springs that are 2.5" and just buy everything else or if i find a 2.5" spring lift kit that has everything and if it can be done will it be safe.
Thanks everyone for your help Ray
Old Nov 20, 2009 | 07:44 PM
spinlock's Avatar
You can do that, but 4.5"+ of lift is going to put you into a wholedifferent
Lift category which will require other mods (CAs, driveshafts, etc)
Sooner or later.
Old Nov 20, 2009 | 07:46 PM
nangulator's Avatar
You will probably be better off ditching the spacers and doing a full spring lift, You will need some more parts though like track bars, LCAs and drive shafts
Old Nov 20, 2009 | 09:04 PM
nthinuf's Avatar
The next time you're browsing around in the Suspension FAQ's, check this one to get an idea of what you're looking at.
Q: What are all the components that I will need with a 4" lift?
Old Nov 20, 2009 | 11:20 PM
Drewsifer's Avatar
Default Go BIG now and save your $
You eventually want it 4,5,6 inches, so get a long arm kit, some Tom Woods shafts, 37's, gears 5:38's, and call it a day
Old Nov 21, 2009 | 05:37 AM
hdrider's Avatar
I've found owning a jeep is like pulling a loose string on a shirt,,, it just keeps going as you keep pulling everything you do seems to effect something else that you now have to change that then effects something else.
I did a 2.5" lift and was happy until I wanted 35's,, so I knew I would rub and put on a 1.75" coil spacer. Well thats great but now my shocks that I bought with the original lift are to short and my drive line is at a pretty good angle.
So new shocks are in the future and who know how long the drive shaft will last.
Not to mention that when I put on the longer shocks and I flex it out my springs will probably come loose. So maybe longer springs or just a retainer might work....... or maybe if I would have done it right and thought it out the 1st time I could have saved some $$$$. But what fun is that.
Old Nov 21, 2009 | 07:26 AM
JK-KJ's Avatar
Check out this thread that's about the same idea...particularly the part about the RC springs...
https://www.jk-forum.com/forums/show...=rough+country
