Light Mod
Old Feb 4, 2008 | 11:02 AM
hydroracer's Avatar
Default Light Mod
I have a 2007 JK 2 door...i have 245/75/16 on there right mow..i am thinking about 265 or 275...i am not going to offroad or anything, but just a road warrior as i have a rhino for that...i am curious as to which you all think would be the better fit..i am also looking at some wheel spacers...any thoughts on them?
Old Feb 4, 2008 | 12:27 PM
wayoflife's Avatar
JK-Forum Founder
Rubicon's and Sahara's come with 255's stock and I have seen 285 installed on them with only minor rubbing at a full turn and full stuff. So, I would go as big as you can as it will help fill in your wheel wells nicely. As far as wheel spacers go, so long as you get something high quality like Spidertrax makes, they will serve you well.
Old Feb 4, 2008 | 01:54 PM
kcpanther's Avatar
i was wanting to get 265's is there any rubbing
Old Feb 4, 2008 | 02:25 PM
TEEJ's Avatar
Talking
255's clear stock...a 265 is only 10 millimeter wider total, so it only sticks out another 5 mm...285's fit stock, and sometimes rub a little at full lock...but not enough for most to care, especially as a little turn out of the turnstops fixes it anyway.
A 285 mm section width is similar to an 11.5" section width tire...maybe ~ one and a quarter inches wider than the 255's....that's where the rub starts it seems.
For a 12.5 -13" section width tire....around a 1.5" spacer seems to work, etc....and that's with 35 - 37" diameter tires, which swing through a wider arc than the stock size tires when you turn, etc.
A 285/75/16 is only about 32" in diameter....the same stock diameter as the 255/75/17 tire option, including the Rubi, etc.
Hope that helps a bit.
Old Feb 5, 2008 | 04:36 PM
hydroracer's Avatar
Default Thanks
I still have not decided...big decision:
not sure what i will do...as far s height difference...and width...need american measurements..i am not going to lit it...just a litttle more aggresive look...
Old Feb 5, 2008 | 04:55 PM
wayland1985's Avatar
here... this should help with your "american measurements" :
http://www.discounttire.com/dtcs/infoTireMath.dos
Old Feb 5, 2008 | 05:10 PM
hydroracer's Avatar
Default Thanks
Thanks..i am not real strong in math....
anybody have a preference between the two...i sthere a gas problem between the two?
Old Feb 5, 2008 | 05:35 PM
No problem with the site. I think wider is probably nice looking. The real question is what do you like?
Fuel economy will likely go down in either case.
